I consolidated several catalogs into the master. On average 400GB each one with any issue at all.
The last one - smaller than those imported previously, has achieved 1/6 of the import in 24 hrs projecting to be completed in the next 3+ days!!!
Before importing it I:
Clearly the UI is not providing any feedback (Adobe, improving this process?) and frankly not sure what I could have done or do differently considering that al my previous imports lasted on average 20 min and worked fine.
Should I abort the import? Did it once after 4 hrs, but the second attempt hasn't delivered a better outcome.
Just wait till the end of the week?
Thanks, Stefano
I eventually managed to consolidate all my catalogues in a master, now 3.4GB in total size and roughly 190K images.
Performance seem OK.
I decided to break down the catalog that required several days to complete the import process in four smaller portions of almost identical dimensions. This solution dramatically shortened the entire process. What will remain a mystery is why two of the four new catalog required several hours each, while the other two completed the process in a matter of minutes.
H
...Copy link to clipboard
Are the LrCat files really 400 GB in size, or is that including the preview folders?
If the LrCat files are really that big, I would leave them as separate catalogs for performance reasons unless you really have a need to merge them.
Had a conversation with Richard Curtis from Adobe at the Birmingham Photography Show and he strongly recommended to create a single catalog with Smart Previews (he claims to have a Master catalog with 300+K images).
Waiting for Apple to introduce new high performance iMacs with Type C ports, to further improve performance.
Thanks, Stefano
Our catalog is 943315 images but it is getting dang slow on imports from other catalogs because it tries to compare each image agains the ones that are in db.
Slow importing can be a hardware problem, perhaps a bad card reader/bad USB cable/bad connection to the camera or to the USB port. I would certainly investigate this, and try importing with different hardware.
Try aborting the import, closing LR, and rebooting the computer. See if that speeds things up.
Bob Frost
