By any chance did "Layer 1 copy 5" have a layer mask in place before the action tried to add one. I it did it may be the reason make layer mask is not and available option. That kind of error message is common error message one see when an action is used on document that structure is not what the action was recorded to process. Action can not use logic to analyze a document state. Actions are just sequential steps. Step, step, step if a the if a document current state does is not correct fo
...Copy link to clipboard
By any chance did "Layer 1 copy 5" have a layer mask in place before the action tried to add one. I it did it may be the reason make layer mask is not and available option. That kind of error message is common error message one see when an action is used on document that structure is not what the action was recorded to process. Action can not use logic to analyze a document state. Actions are just sequential steps. Step, step, step if a the if a document current state does is not correct for the current action step the step will fail.
Single step through the action see where thing go wrong.
Crafting Actions Package UPDATED Aug 10, 2014 Added Conditional Action steps to Action Palette Tips.
Contains
i can't understand what i have to do
I do this and the step that stop in is this
I wrote it look like that layer has a layer mask. So make layer mask would not be an available option. Like the message states.
