Hi there,
I'm a heavy Lightroom CC user and always have the latest version installed. For every shot I take I'll make sure that the correct lens profile is selected.
I own perhaps ten lenses and it takes so long to scroll through the full list to find the one that I want. Is there a way to delete the lens profiles that I'll never use?
Many thanks,
Gary
Why are you doing this manually?
You can define a preset and apply this during the import - the correct profile is then always selected and activated automagically.
Thank you for your reply. It prompted me to dig a little deeper. My 85mm lens was being selected a lot of the time which was causing me the confusion and making me select the lens profile manually. I noticed that in the 'Enable Profile Corrections' section 'Custom' was selected instead of 'Auto'. This was the case for about 20% of my presets so I couldn't figure it out... until you replied and made look at it in more detail. I thank you.
OK - come back here if something's not working as supposed or expected.
