Videos as Particles?
Engaged ,
Mar 19, 2017 Mar 19, 2017
I've been using CC Particle World a lot and I've noticed that the ability to use static images as textures for the particles is an option.  However, is it possible to create any sort of particle effect that actually uses footage or multiple frames as the texture in After Effects?  For example, let's say that I have 60 low-resolution frames that form a perfect loop when repeated.  Would there be any way for each particle to use all of these frames so that the particle's texture also appears to be in motion, or am I always limited to using static textures?
663
LEGEND , Mar 19, 2017 Mar 19, 2017
Particle World doesn't support random temporal sampling and otehr fancies, so you are out of luck. You would have to buy Trapcode Particular or other advanced third-party effects that offer more features in that department.
Mylenium
Mylenium
Mar 21, 2017 Mar 21, 2017
Mylenium is right. Particular would be perfect for this.
Guest
Jun 17, 2017 Jun 17, 2017
particle has supported  on AE  cc2014 ?
yes. it does lack advanced options (like the ones you would find in particular) but you can use a video instead of a still layer. just select it in the texture layer as usual. to make it loop just use the interpret footage dialog in the project panel.
