On the home page I am experiencing horizontal scrolling/shift (whatever you want to call it).
Things I've done to try to fix the problem:
-made sure all text boxes and objects are 320px or less and ensured they are set to responsive width & height
-pinned/anchored everything to the center
-verified the elements in the master page are responsive
It's only the home page, so worse case scenario I could probably duplicate a page that doesn't have the issues and replace the homepage with it. I rather try to see if I can fix it first.
Any ideas or suggestions?
Your problem is with a text box about half way down .... as you can see when you adjust the size the text box remains outside the design in this screenshot. Making that text box narrower solves the problem.
Do a 'Select All' so that everything is hi lighted and you will likely find an empty text container or something that is off the page.
I was so hopeful that it was something that easy! No hidden objects or text boxes anywhere off the page. Any other suggestions?
Have you tried on both your pages and your master pages?
Yup! On master and home page. I'm not sure if this is allowed, but here's a link to a duplicated file
