Hello,
Ive been told that somehow the template I created in dreamweaver affects the css that controls BC modules, my site currently does not look like the one i created in DW althought I have upload the newest version. I have been playing ping pong between BC techs and DW and BC said that they cant help me with code, I hope you guys can assist me. Here is the code I have for the template. Please feel free to share your thoughts. thank you.
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1"><meta name="author" content="IbarDesign">
<!-- TemplateBeginEditable name="doctitle" -->
<title>Veneto Luce | Home</title>
<!-- TemplateEndEditable -->
<link rel="shortcut icon" href="../images/_svg/Veneto_logo_solo_b.svg"/>
<!-- Bootstrap -->
<link href="/css/bootstrap.css" rel="stylesheet">
<link href="/css/style.css" rel="stylesheet" type="text/css">
<!-- HTML5 shim and Respond.js for IE8 support of HTML5 elements and media queries -->
<!-- WARNING: Respond.js doesn't work if you view the page via file:// -->
<!--[if lt IE 9]>
<script src="https://oss.maxcdn.com/html5shiv/3.7.2/html5shiv.min.js"></script>
<script src="https://oss.maxcdn.com/respond/1.4.2/respond.min.js"></script>
<![endif]-->
<!--The following script tag downloads a font from the Adobe Edge Web Fonts server for use within the web page. We recommend that you do not modify it.-->
<script>var __adobewebfontsappname__="dreamweaver"</script>
<script src="http://use.edgefonts.net/syncopate:n4:default.js" type="text/javascript"></script>
</head>
<body>
<header class="header">
<nav class="navbar navbar-default">
<div class="container">
<!-- Brand and toggle get grouped for better mobile display -->
<div class="navbar-header">
<button type="button" class="navbar-toggle collapsed" data-toggle="collapse" data-target="#defaultNavbar1" aria-expanded="false"><span class="sr-only">Toggle navigation</span><span class="icon-bar"></span><span class="icon-bar"></span><span class="icon-bar"></span></button>
<a class="navbar-brand" href="../html/index.html" title="Veneto Luce"></a></div>
<!-- Collect the nav links, forms, and other content for toggling -->
<div class="collapse navbar-collapse" id="defaultNavbar1">
<ul class="nav navbar-nav">
<li class="active"><a href="../html/index.html">HOME<span class="sr-only">(current)</span></a></li>
<li class="dropdown"><a href="#" class="dropdown-toggle" data-toggle="dropdown" role="button" aria-haspopup="true" aria-expanded="false">SHOP<span class="caret"></span></a>
<ul class="dropdown-menu">
<li><a href="http://www.venetoluce.com/veneto-luce-lighting ">LIGHTING</a></li>
<li><a href="../html/home-decor.html">DECOR</a></li>
<li><a href="http://www.venetoluce.com/veneto_luce_wholesale-sign-up.html">WHOLESALE</a></li>
</ul>
</li>
<li><a href="../html/about-us.html">ABOUT US</a></li>
<li><a href="">CONTACT US</a></li>
<li><a href="">LOG-IN</a></li>
<form name="catsearchform59779" method="post" action="../search-results.html"><div class="search-box"><input class="cat_textbox_small" type="text" name="CAT_Search" id="CAT_Search" /><input class="cat_button" type="submit" value="Search" /></div></form>
</ul>
</div>
<!-- /.navbar-collapse -->
</div>
<!-- /.container-fluid -->
</nav>
</header>
<!-- TemplateBeginEditable name="content" -->content<!-- TemplateEndEditable -->
<!-- footer -->
<footer class="footer">
<div class="row">
<div class="col-lg-4">
<div id="menu">
<ul>
<li class="heading">LIGHTING</li>
<li><a href="http://www.venetoluce.com/veneto-luce-lighting/ceiling-lighting" title="Ceiling Lighting">CIELING</a></li>
<li><a href="http://www.venetoluce.com/veneto-luce-lighting/wall-lighting" title="Wall Lighting">WALL</a></li>
<li><a href="http://www.venetoluce.com/veneto-luce-lighting/floor-lighting" title="Floor Lighting">FLOOR</a></li>
</ul>
</div>
</div>
<div id="contact info">
<a href="https://www.facebook.com" target="_blank" title="Veneto Luce Facebook" ><img id="social-media-veneto" src="../images/_social_icons/white/veneto_luce_fb_w.svg" alt="veneto luce instagram" href="facebook.com"/></a>
<a href="https://www.twitter.com" target="_blank" title="Veneto Luce Twitter"><img id="social-media" src="../images/_social_icons/white/veneto_luce_tw_w.svg" alt=""/></a>
<a href="https://www.instagram.com" target="_blank" title="Veneto Luce Instagram"><img id="veneto-luce-instagram" src="../images/_social_icons/white/veneto_luce_ig_w.svg" alt=""/></a>
</div>
<div id="veneto luce address">
<h5 class="address">490 s. san vicente blvd. #8 </h5>
<h5 class="address">west hollywood, ca. 90048</h5>
</div>
<div id="veneto luce phone">
<h3 id="phone"><a href="tel:+14243334511" title="Veneto Luce Phone Number">424-333-4511
<span class="sr-only">phone number contact</span></a></h3>
</div>
</div>
<div id="veneto links">
<ul>
<li class="heading">VENETO LUCE</li>
<li><a href="../html/return-policy.html">RETURN POLICY</a></li>
</ul>
</div>
</div>
</div>
</footer>
<!-- jQuery -->
<!-- <script src="js/jquery.js"></script> -->
<script src="../js/jquery-1.11.3.min.js"></script>
<!-- Bootstrap Core JavaScript -->
<script src="../js/bootstrap.min.js"></script> <!-- Script to Activate the Carousel -->
<script>
$('.carousel').carousel({
interval: 5000 //changes the speed
</script>
</body>
</html>
Have something to add?
