Hi, I`ve got a problem with text selection in InDesign. When I try to select the text It works after a few seconds and It is annoying. Cant normally work. I also noticed problem with glyph panels, I can not scroll the glyphs. Maybe some font is causing this problem? or operating system?
does anyone know? Thanx
Mariusz
Which version of InDesign and operating system do you have?
In the meantime try trashing your InDesign Preferences:
Close and relaunch InDesign, and IMMEDIATELY hold down Ctrl + Alt + Shift (Windows) or Cmd + Ctrl + Opt + Shift (Mac), and respond in the affirmative to the dialog asking if you really want to replace the preferences. you must be extremely fast on the keyboard (if you don’t see the confirmation prompt, you were too slow)
You may have to do it a couple of times before you get the hang of it!
Hi
I did that and looks ok for that moment
thanx for your help
M
Good, but you didn't answer the first question.
Yes, sorry,
ID CC2017
Win 10 64 bit
