Hello,
I'm trying to make a new gradient which should be added in gradient preset manager. I would like add more user defined gradient steps and unique colors.
Using xbytors action to javascript tool I was able to create script (at the bottom of post.) But as it gets so complex for more steps controlling them become harder, so I thought there should be a way to put following lines under a function...(I noticed that those are the lines for defining rgb color and location, and it repeating as I add more steps..)
var desc4 = new ActionDescriptor();
var desc5 = new ActionDescriptor();
desc5.putDouble(cTID('Rd '), 0);
desc5.putDouble(cTID('Grn '), 0);
desc5.putDouble(cTID('Bl '), 0);
desc4.putObject(cTID('Clr '), sTID("RGBColor"), desc5);
desc4.putEnumerated(cTID('Type'), cTID('Clry'), cTID('UsrS'));
desc4.putInteger(cTID('Lctn'), 0);
desc4.putInteger(cTID('Mdpn'), 50);
list1.putObject(cTID('Clrt'), desc4);
I tried to convert it to a function like this; ( Should I give desc5,desc4 variables unique names? )
function addgradientstep(redcolor,greencolor,bluecolor,location) {
desc5.putDouble(cTID('Rd '), 0); // Red Color
desc5.putDouble(cTID('Grn '), 0); // Green Color
desc5.putDouble(cTID('Bl '), 0); // Blue Color
desc4.putInteger(cTID('Lctn'), 0); // Gradient Step Location
And I thought I would call them like; ( I don't need to do anything with transparency options by the way, only color steps...) ( It gave an error at this line ;
step1();
addgradientstep(255,255,255,0);
addgradientstep(0,0,0,25);
addgradientstep(128,128,128,50);
step2();
Full script;
#target photoshop
cTID = function(s) { return app.charIDToTypeID(s); };sTID = function(s) { return app.stringIDToTypeID(s); };
var steps = 10;
function Simple_Gradient() {
var desc1 = new ActionDescriptor();
var ref1 = new ActionReference();
ref1.putClass(cTID('Grdn'));
desc1.putReference(cTID('null'), ref1);
var desc2 = new ActionDescriptor();
var desc3 = new ActionDescriptor();
desc3.putString(cTID('Nm '), "GradientName");
desc3.putEnumerated(cTID('GrdF'), cTID('GrdF'), cTID('CstS'));
desc3.putDouble(cTID('Intr'), 4096);
var list1 = new ActionList();
var desc6 = new ActionDescriptor();
var desc7 = new ActionDescriptor();
desc7.putDouble(cTID('Rd '), 255);
desc7.putDouble(cTID('Grn '), 255);
desc7.putDouble(cTID('Bl '), 255);
desc6.putObject(cTID('Clr '), sTID("RGBColor"), desc7);
desc6.putEnumerated(cTID('Type'), cTID('Clry'), cTID('UsrS'));
desc6.putInteger(cTID('Lctn'), 4096);
desc6.putInteger(cTID('Mdpn'), 50);
list1.putObject(cTID('Clrt'), desc6);
desc3.putList(cTID('Clrs'), list1);
var list2 = new ActionList();
var desc8 = new ActionDescriptor();
desc8.putUnitDouble(cTID('Opct'), cTID('#Prc'), 100); // Start Opacity
desc8.putInteger(cTID('Lctn'), 0); // Location
desc8.putInteger(cTID('Mdpn'), 50); // Mid Point
list2.putObject(cTID('TrnS'), desc8);
var desc9 = new ActionDescriptor();
desc9.putUnitDouble(cTID('Opct'), cTID('#Prc'), 38.0392156862745); // End Opacity
desc9.putInteger(cTID('Lctn'), 4096); // Location
desc9.putInteger(cTID('Mdpn'), 50); // Mid Point
list2.putObject(cTID('TrnS'), desc9);
desc3.putList(cTID('Trns'), list2);
desc2.putObject(cTID('Grad'), cTID('Grdn'), desc3);
desc1.putObject(cTID('Usng'), cTID('Grdn'), desc2);
executeAction(cTID('Mk '), desc1, DialogModes.NO);
Simple_Gradient();
// for (i = 0; i < steps; i++){}
Thank you,
Best Regards.
Does this help?
// 2017, use it at your own risk;
#target photoshop
var theGradient = gradientLayer([[0,0,0,0], [1000,128,128,255], [2000,255,255,0]]);
function gradientLayer(theArray) {
var idClr = charIDToTypeID( "Clr " );
var idRd = charIDToTypeID( "Rd " );
var idGrn = charIDToTypeID( "Grn " );
var idBl = charIDToTypeID( "Bl " );
var idRGBC = charIDToTypeID( "RGBC" );
var idLctn = charIDToTypeID( "Lctn" );
var idMdpn = charIDToTypeID( "Mdpn" );
var idOpct = charIDToTypeID( "Opct" );
var idPrc = charIDToTypeID( "#Prc" );
var idTrnS = charIDToTypeID( "TrnS" );
var idType = charIDToTypeID( "Type" );
var idMk = charIDToTypeID( "Mk " );
var desc10 = new ActionDescriptor();
var idnull = charIDToTypeID( "null" );
ref1.putClass( idcontentLayer = stringIDToTypeID( "contentLayer" ) );
desc10.putReference( idnull, ref1 );
var idUsng = charIDToTypeID( "Usng" );
var desc11 = new ActionDescriptor();
var desc12 = new ActionDescriptor();
desc12.putBoolean( charIDToTypeID( "Dthr" ), true );
desc12.putUnitDouble( charIDToTypeID( "Angl" ), charIDToTypeID( "#Ang" ), 0.000000 );
desc12.putEnumerated( idType, charIDToTypeID( "GrdT" ), charIDToTypeID( "Lnr " ) );
var idGrad = charIDToTypeID( "Grad" );
var desc13 = new ActionDescriptor();
var idNm = charIDToTypeID( "Nm " );
desc13.putString( idNm, "Custom" );
var idGrdF = charIDToTypeID( "GrdF" );
desc13.putEnumerated( idGrdF, idGrdF, charIDToTypeID( "CstS" ) );
var idIntr = charIDToTypeID( "Intr" );
desc13.putDouble( idIntr, 4096.000000 );
// insert color stops;
for (var m = 0; m < theArray.length; m++) {
var desc14 = new ActionDescriptor();
var desc15 = new ActionDescriptor();
desc15.putDouble( idRd, theArray
[1] ); desc15.putDouble( idGrn, theArray
[2] ); desc15.putDouble( idBl, theArray
[3] ); desc14.putObject( idClr, idRGBC, desc15 );
var idClry = charIDToTypeID( "Clry" );
var idUsrS = charIDToTypeID( "UsrS" );
desc14.putEnumerated( idType, idClry, idUsrS );
desc14.putInteger( idLctn, theArray
[0] ); desc14.putInteger( idMdpn, 50 );
var idClrt = charIDToTypeID( "Clrt" );
list1.putObject( idClrt, desc14 );
desc13.putList( charIDToTypeID( "Clrs" ), list1 );
var idTrns = charIDToTypeID( "Trns" );
var desc18 = new ActionDescriptor();
desc18.putUnitDouble( idOpct, idPrc, 100.000000 );
desc18.putInteger( idLctn, 0 );
desc18.putInteger( idMdpn, 50 );
list2.putObject( idTrnS, desc18 );
var desc19 = new ActionDescriptor();
desc19.putUnitDouble( idOpct, idPrc, 100.000000 );
desc19.putInteger( idLctn, 100 );
desc19.putInteger( idMdpn, 50 );
list2.putObject( idTrnS, desc19 );
desc13.putList( idTrns, list2 );
var idGrdn = charIDToTypeID( "Grdn" );
desc12.putObject( idGrad, idGrdn, desc13 );
desc11.putObject( idType, stringIDToTypeID( "gradientLayer" ), desc12 );
desc10.putObject( idUsng, stringIDToTypeID( "contentLayer" ), desc11 );
executeAction( idMk, desc10, DialogModes.NO );
return activeDocument.activeLayer
