Remove Fill on paths not quite working
Advisor ,
Mar 21, 2017 Mar 21, 2017
Why aren't all the paths that may have a fill on them, within the layer by name "Hairs_TopNose" not being iterated though and having, if exists their fill removed ?
var curDoc = app.activeDocument;
var lyr = curDoc.layers.getByName("Hairs_TopNose");
var pathss = lyr.hasSelectedArtwork;
var pth = lyr.pathItems.length;
var patth = lyr.pathItem;
if (pathss==1) {
    for(pth=0;pth<patth.filled=false;i++)
    }else{
        alert("Fill on Paths Removed");
Scripting
1.1K
Guide , Mar 22, 2017 Mar 22, 2017
and in the if statement you have the wrong var as well.
while (i--) {
if (patth.filled) {
  patth.filled=false
use pth not patth.
pth is the array of path items
patth is the number of items in the array.
Adobe
Valorous Hero ,
Your for-loop, looks like it is missing.
Advisor ,
When you said missing; I realized I missed a curly brace, until adding it I got an error I didn't previous have, illegal use of the word else.
Participant ,
If I understood the problem correctly, then:
var layer = activeDocument.layers.getByName('Hairs_TopNose'),
    items = layer.pathItems,
    i = items.length,
    check = false;
while (i--) {
    if (items.filled) {
        items.filled = false;
        check = true;
if (check) alert('Fill on Paths - Removed!');
    else alert('Fill on Paths - Not found!');
Advisor ,
@Alexander Ladygin, check is a variable, correct ?
What was wrong with the code approach I took; the loop is what I can see ?
Participant ,
Try putting the if statement inside of the for loop, this code assumes that none of the path items are grouped:
// get a reference to all the path items in the layer,
//   doesn't include any paths that are in groups or sublayers
var paths = layer.pathItems;
var curPath;
// loop through each index in the array of path items
for( var i = 0, ii = paths.length; i<ii; i++ ) {
     // get a reference to the current path
     curPath = paths;
     // check if it has a fill color
     if( curPath.filled == true ) {
          // remove its fill color
          curPath.filled = false;
If you are using CS6 or newer, the 'executeMenuCommand' might also be a good approach:
#target illustrator
function test() {
     // get references to the document and the layer
     var doc = app.activeDocument;
     var layer = doc.layers.getByName( "Hairs_TopNose" );
     // clear any current selections
     doc.selection = null;
     // select all the art on the layer and unlock and show it
     layer.hasSelectedArtwork = true;
     app.executeMenuCommand( "unlockAll" );
     app.executeMenuCommand( "showAll" );
     // reset the selection and clear any fill colors
     doc.defaultStrokeColor = new NoColor();
     // clear the selection
test();
Advisor ,
This is altered to what Alexander Ladygin posted, except there is an error on line 4; which is odd because it's identical to the same line in his code ?
var pth = layer.pathItems;
var patth = pth.length;
var verify = false;
while (i--) {
    if (patth.filled) {
        patth.filled=false;
        verify=true;
if (verify) alert("Fill on paths removed");
else alert("Fill on paths not removed");
Participant ,
Change 'layer.pathItems' to 'lyr.pathItems', I hate when that happens!
Advisor ,
Thanks, although now i the variable in the while loop is undefined ?
Guide ,
change the line:
to
var i = pth.length;
Guide ,
while (i--) {
if (patth.filled) {
  patth.filled=false
use pth not patth.
Advisor ,
Qwertyfly...​You mean var i is now the number of items in the array and pth is the list of the path items
Qwertyfly...​Thank you and thank you to everyone who helped as well
Guide ,
try this.
renamed the variables so it makes more sense.
var myDoc = app.activeDocument;
var myLayer = myDoc.layers.getByName("Hairs_TopNose");
// the line here was not used
var myPaths = myLayer.pathItems;
var myPathQty = myPaths.length;
var verify = false;
var i = myPathQty;
while (i--) {
    if (myPaths.filled) {
        myPaths.filled=false;
        verify=true;
