After updating website in muse, the home page is off center to the left, with no page border showing. All other pages are fine. Haven't experienced this in the 10 months I've been doing our website. I've made no change to settings that I'm aware of. I've checked online for solutions, i.e. looking for rogue invisible objects on the page in question. Can't find a solution that solves the problem. Any help would be appreciated.
The site is http://www.bethelcmc.org Images below: home page (off center) and below that another page , indicative of the remaining pages appearing normally.
Thanks for the advice Gunter. I realized that I had made an unintended change in the metadata in page properties. Deleted the change and everything is back to normal. Thanks again for the info!
Hi justina,
Create a new site with only one page and only the misbehaving elements, or reduce your existing site to only one page, containing the elements, which demonstrate your issue. (This is helpful because it saves download and analyzing time).
Upload this .muse file(!) to Dropbox or a similar file sharing service and provide the download link here.
Then we can have a closer look.
Ankush
Thank you so much Ankush. Will do so shortly!
You know, that you can adjust page alignment, page fill and stroke page-wise and independently from you master page settings?
Your pages use the master page settings as long as you don’t define extra settings per page.
You can set these values in the upper control strip, when no page element is selected. The page alignment can be set in "Page Properties" (small icon to the right of the "Padding" input fields).
Ankush, As I was prepping the site file to send, I thought to check the page properties one more time. I realized that I had made an unintended change to the page properties from the previous version. Deleted that change and everything is back to normal. Thanks so much!
