Please help! Infuriating issue with printer presets and javascript
Mar 22, 2017 Mar 22, 2017
Hello world,
     I have an issue that is driving me insane. I am trying to make a script that will either install or modify/update a printer preset and this is my current code:
try { //Install
   var SNAPPI_C654_8point5x11 = app.printerPresets.add();
   with (SNAPPI_C654_8point5x11) {
   name =  "SNAPPI_C654_8.5x11";
   printer = "Bizhub C654e PS";
   pagePosition = PagePositions.centered;
   printBlankPages = true;
   cropMarks = false;
   pageRange =  PageRange.ALL_PAGES;
   pageWidth = "8.5in";
   pageHeight = "11in";
   paperSize = PaperSizes.CUSTOM;
   colorOutput = ColorOutputModes.COMPOSITE_CMYK;
    catch (err) { //Update
   with (app.printerPresets.itemByName("SNAPPI_C654_8.5x11")) {
   cropMarks = false;
I have also tried:
with (app.printerPresets.item("SNAPPI_C654_8.5x11")) {
as my catch.
The first time I run the script, everything works flawlessly. If I run it again with no catch, it crashes. If I run it again with a catch, it continues CREATING NEW PRESETS with default names (printer preset 1, 2, ....). Why does it keep creating NEW presets each time it is ran when I am EXPLICITLY referencing a preset that ALREADY EXISTS and do not have a command to .add?!?
This is essentially the installer script for a larger project I am working on and this one is driving me crazy. Any help is deeply appreciated!!!!!!
Scripting
416
Advisor ,
Just this time:
var SNAPPI_C654_8point5x11 = app.printerPresets.item('SNAPPI_C654_8.5x11');
if (!SNAPPI_C654_8point5x11.isValid) {
  SNAPPI_C654_8point5x11 = app.printerPresets.add({
    printer: "Bizhub C654e PS",
    pagePosition: PagePositions.centered,
    printBlankPages: true,
    cropMarks: false,
    pageRange: PageRange.ALL_PAGES,
    pageWidth: "8.5in",
    pageHeight: "11in",
    paperSize: PaperSizes.CUSTOM,
    colorOutput: ColorOutputModes.COMPOSITE_CMYK
Down the line, do yourself and those that might have to work after you with your code and read up a bit on JS conventions and style guides to see why you should not name your variables like "SNAPPI_C654_8point5x11" or use "with"
Mar 23, 2017 Mar 23, 2017
Thanks! This is my first scripting project so I am still very new to all of this. Do you have any particular references or sites you would recommend? I only use with because I am not aware of another way to accomplish the same effect, how does isValid work, is it checking if the name is already a valid reference or if creating a new entry with that name is a valid action?
     Also, will this code also work to update the existing preset if ran more than once? The values may change in future versions and I want it to be able to update the presets to reflect possible changes. Thanks again for helping a newbie!
