I have a memory card reader for my iPad. Can I import the photos directly from card into Lightroom or will have to import into camera roll first?
thanks for your help
You have to go to the camera roll first which is a limitation imposed by Apple. Only the photos app can access the memory card reader. This is also annoying as the Photos app will start syncing the raw files with iCloud right away. Some observations on that workflow here: Jao's photo blog: A mobile workflow with Lightroom?
Moving to Photoshop Lightroom
Apparently there is a limitation in iOS that prevents third party apps from using the SD card reader. This is not a limitation on Android. The only way to work with the card reader to go through the camera roll... And I can tell you that it is a slow and painful process.
There is another option... you can get an external hard drive, such as ones by LaCie or Western Digital that are made for mobile photography. They have built-in SD card readers, imporat directly to the drive, and because you can access the files via the Files app in iOS 11, they can be directly imported into Lightroom. This option also solves for the missing “backup on import” feature.
https://www.lacie.com/products/dji-copilot/
https://www.wdc.com/products/portable-storage/my-passport-wireless-ssd.html
