Hello creatives,
is there any way I can change the canvas size and orientation of an existing document? (not a new one)
thank you!
Eskilee.
I'm sorry, in the current version of Draw it's not possible to change the canvas size once you've begun drawing. I know it doesn't do you a lot of good for this drawing, but that is a feature that will be in the next version of the app (which should be available in a couple of weeks).
I hope that helps a bit.
Sue.
Hi Elisa,
Are you trying to change the canvas size of a new document or getting a document from any other app like, Illustrator desktop app?
Sheena
HI!
I have a Draw document and I want to change the size of the canvas.
Change, not making a new one. I realised I didn't have enough space to draw.
cheers
Also, can you confirm me which device are you using? Also the OS version for the same?
yes sure,
iPad pro 12.9 inches.
Not sure about the OS version
Eskilee.
Sue.
Thank you Sue, that' helpful. Can't wait for the new version!
Eskilee.
Hang in there. It won't be too much longer.
Sue.
How make too bigger canvas size in new document. I need 600 cm and AI show that maximum is 577 cm, Can this change?
I need help now. Thx.
Ola.
Are you working on Illustrator? If so, please repost on Illustrator because you've posted on the forum for Draw (a mobile app) and I'm unable to move your post because it's part of another one.
Let me know if I've misunderstood and you're referring to Draw.
Sue.
Sorry,
Illustrator and adobe help redirect me here. Yes, I work in the Ilustrtor and I can't make a bigger file than above. Can you help me?
Ola.
For help with Illustrator, you need to post your question in this other forum: Illustrator
Sue.
I'm using Illustrator on my note 8 and I can't seem to change the canvas size, is this possible in the current version? If not is there a way to transfer the vector drawing to a larger canvas size?
Brad.
