I'm trying to get a silent install package working and while the install completes correctly, running any updates for CF result in a 500 error that I cant resolve. It does this whether I install the hotfixes through CF admin or manually
I can reproduce this in my lab every time, but found that if I install CF interactively, everything works great and the updates are successful
I'm not sure what I might be missing in the silent install thats causing this behavior. VC++2012 is already installed, and thats the only difference I noticed between the two
The error I'm seeing after updating to hf-11-0011 is below (this is just from CFAdmin). The update log shows everything is SUCCESSFUL
type Exception report
message
description The server encountered an internal error that prevented it from fulfilling this request.
exception
java.lang.NullPointerException coldfusion.monitor.error.RequestErrorMonitorEventHandler.onRequestEnd(RequestErrorMonitorEventHandler.java:31) coldfusion.monitor.event.RequestMonitorEventProcessor.onError(RequestMonitorEventProcessor.java:558) coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:69) coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46) coldfusion.filter.ClickjackingProtectionFilter.doFilter(ClickjackingProtectionFilter.java:75) coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
Have something to add?
