Where are After Effects files automatically saved?
Mar 24, 2017 Mar 24, 2017
I use Adobe After Effects CC 2017, and auto-save is turned on by default. The path of auto-save is marked as "Next to Project". My computer turned off yesterday, because of electricity. So where can I find my lost project?
How to
191.7K
People's Champ , Mar 24, 2017 Mar 24, 2017
Wherever you last saved your project.
I'm not sure whether or not After Effects will auto-save an untitled project..maybe it does.
Regardless, when you start a new project you always save it in it's own folder and name it.
Then you can keep any assets & project related files all in one place & autosave will have a project to "save next to".
If you screwed up or don't know what you're doing & were working on an "untitled project" you could try opening AE,  hitting CTRL+ALT+N  to start a new project,
People's Champ ,
If you screwed up or don't know what you're doing & were working on an "untitled project" you could try opening AE,  hitting CTRL+ALT+N  to start a new project,  then immediately go (as you always should) to File>SaveAs  & see what folder it defaults to.  If there's something saved it might be there.  Otherwise it might be in Documents\Adobe\AfterEffects (or whtever file path is greyed out in the autosave preference dialogue).   You could also search your computer for ".aep" files.
After that....you're out of luck. Live & learn.
REMINDER:  When you start a project always save it immediately with a unique name in a dedicated project folder.   Then when auto-save, which is set to save "next to project",  saves,  there will be a "project" for it to save "next to".
~Gutterfish
Contributor ,
Apr 06, 2018 Apr 06, 2018
@gutterfish:
no it doesn't.
AE doesn't automatically save files that have not been saved by the user. this means: untitled files, are not saved... and by extension files that have been converted from older AE versions do not save. I 'get' why this is, but it's poor implementation to say the absolute minimum. And if I'm being completely honest, unbridled fury is fueling my comments. I've just lost some work that will be vary difficult to reproduce with precision, due to a crash caused by AE, with no backups due in no small part to Adobe's inability to understand that 'converting a file from an older version of After effects' does not immediately register to the user as an unsaved, new project. this is AE CC 2018, btw. a Completely bug-ridden mess.
People's Champ ,
I'm not exactly sure what you just said but I was able to gleen that you lost some work.  Bummer.
BTW I never said After Effects saves untitled projects.  I said I wasn't sure.
I also manually save (CTRL+S) every 20 minutes or so just out of habit.
Finally, if I've learned anything in my short time here among you humans it's this:
Outside the context of telling someone a difficult truth...like that they smell or that they're stupid,...
whenever someone starts a sentence with "and if I'm being completely honest", the next sentence is usually an exaggeration if not complete baloney.
~Gutterfish
Contributor ,
you said: "maybe it does"
I was clarifying it for you.
People's Champ ,
I see. Thanks, that's good to know.
~Gutterfish
Jan 18, 2023 Jan 18, 2023
Unfortunately this just happened to me in 2023
May 25, 2018 May 25, 2018
If you have Auto Save on:
-Documents\Adobe After Effects Auto-Save
And select the last created file.
I also had some issues since the After Effects does not automatically opens the last auto-save part of the project but instead the part where you saved it manually. Hope I could Help.
Sep 25, 2018 Sep 25, 2018
Hello,
To have the program auto-save, you have to set it up.  Edit > Preferences > Auto-Save > then pick your settings
If you do not have it set-up then you are poop out of luck.  I just switched to CC 2018 and forgot to hook it up.  I checked all adobe source folders, even in appdata.  Nothing.
Also, the auto-save will auto-save an untitled project.
People's Champ ,
That one catches alot of people.
~Gutterfish
Nov 05, 2018 Nov 05, 2018
Yeah, I had autosave turned on to save "next to project" yet it did NOT save.
I hate things and stuff.
Nov 27, 2018 Nov 27, 2018
I found a way. Install a software like ëverything" then search for .aep files. then click on date modified and you should have a temp file whether you saved it or not.
Nov 24, 2019 Nov 24, 2019
Do you have a linc to that software?
Nov 29, 2019 Nov 29, 2019
A bit late for this topic but I found a way to recover an unnamed file with a few limitations.
Only condition is you pushed the comp you were working with into media encoder before crashing:
Do a right click on the comp listed in MediaEncoder and choose "Show Source File" (Hope this is translated correctly since I'm using the German version).
It should prompt you a temp folder where your composition is saved.
(tmpAEtoAMEProject-COMPNAME.aep)
This will unfortunately only bring back this comp only and the media used for it but for some people this might do the trick.
Aug 24, 2020 Aug 24, 2020
Thank you soooooo mmmmuch!!!
You saved me hours of work.  I was so @#$%#@!&^!!
Going to Media Encoder and right clicking on the Ae file and selecting "reveal source file" found my unsaved Ae project in : AppData>Local>Temp>my file...
Oct 12, 2021 Oct 12, 2021
Oh, thank you. I found my projects file with closing Media Encoder in one of the temp folders.
Mar 10, 2022 Mar 10, 2022
Brooo!!! I LOVE U SOOO MUCHH
May 17, 2023 May 17, 2023
Just got a crash on unsaved document and i found the autosave at
C:\Users\-username-\AppData\Local\Temp\Untitled Project_AME
Hope it helps somebody.
Mar 09, 2024 Mar 09, 2024
Hey bro, i followed ur steps but I cant find the last one untitled files_ame, there are so many empy files but not that
perhaps your AE crashed before it could autosave the doc. No idea man, sorry..
  • Pls respond i need
