I'm going to try to explain it in English. I speak Dutch namely.
When I have a picture open in lightroom and I want to do an edit in photoshop CC I have problems.
Right click-Edit in photoshop
Photoshop CC opens the picture, but the program blocks.
There is no problem when Photoshop CC in separate use.
Only when I want to switch directly from Lightroom to Photoshop;.
Currently I have 6 GB of Ram memory.
actually that sounds like lr is blocking ps which is pretty reasonable. if you close lr are then able to open in ps?
[moved from Adobe Creative Cloud to Photoshop Lightroom]
Yes, that is possible.
test it and see.
if that's the issue, user error is the problem.
You -should- be able to edit in Photoshop with Lightroom open and after saving, see your Photoshop file available in the same Lightroom folder for further editing. When you say the Photoshop opens the picture, but blocks - can you explain more... are editing features grayed out or unavailable? What happens exactly? Also, there is a translate function here for "Nederlands" - see lower right bottom of each post, so we should be able to translate.
"..with Lightroom open and after saving.." is key. are you editing in lr and failing to save when opening in ps?
