Check Textframe content
Engaged ,
Mar 24, 2017 Mar 24, 2017
Hello!
My „mission“ this time is - shortly explained -  to re-format some tables in a magazine.
For the case one chose one or more Textframes, there is a condition at the beginning of the script:
var myDoc = app.documents[0];
var myPage = myDoc.pages[0];
var allSelection = myDoc.selection;
var mySelection = allSelection[0];
var numbSelection = allSelection.length;
for (var i=0; i < numbSelection; i++) {
    if (allSelection.constructor.name != "TextFrame") {
        alert("Bitte wähle einen Textrahmen aus! " + allSelection + " ist KEIN Textrahmen!");
    else if (allSelection.contents.constructor.name != "Table") {
        alert("Der Textrahmen benhaltet keine Tabelle!");
    else {alert("Die Show kann beginnen!")};
All I want to know now is, where is my fault (line 13.)? I want to check if there is a table inside.
Scripting
639
Community Expert , Mar 24, 2017 Mar 24, 2017
else if (allSelection.tables.length > 0) {
Though this works only for frames in which a table starts. If the frame contains part of a table that continues from the previous frame you won't be able to test it like this.
P.
P.
Engaged ,
Thank you Peter.
But, maybe in my case it has look like:
else if (allSelection.tables.length < 0) { ... ?
than it works, cool!
I didn't didn't see the 'k' in 'Der Textrahmen benhaltet keine Tabelle'.
The difference one single letter can make!
P.
Engaged ,
Mar 29, 2017 Mar 29, 2017
If you don´t mind...
I think it must be the "1" instead the "0", like this:
else if (allSelection.tables.length < 1) { ... ?
What do you think?
Mar 30, 2017 Mar 30, 2017
If a frame does not contain any tables, allSelection.tables.length === 0. So if you want to test whether a frame contains any tables, you use if (allSelection.tables.length > 0).
Engaged ,
Mar 31, 2017 Mar 31, 2017
I don´t know why, but when I try:
if (allSelection.tables.length > 0)...
I get allways (with each text frame selected) the result "Die Show kann beginnen!". Means, there was detected a table, even if there isn´t one.
If I try:
it works like it should.
If length < 1 does what you want, then that's what you should use.
