Hello fellow Acrobat users ...
This is my first post, so please forgive me if i am too detailed or not detailed enough
My question is ... Why does the formula not work consistency?
Thank you very mush in advance for your help
I have created a form that allow a single field to populate other fields
Field 1 A date is entered e.g. 01- apr 2017
Fields 2-8 - Whatever is entered into Field 1 is auto-populated into fields 2-8 ... minus 1 day starting from 8 back through to 2, incrementing
Using the format "dd - mmm - YYYY" ... mmm is Caps on first letter
e.g.
Field 1 03 apr 2017
Field 2 28 Mar 2017 - Matches Field 1 ... - 6
Field 3 29 Mar 2017 - Matches Field 1 ... - 5
Field 4 30 Mar 2017 - Matches Field 1 ... - 4
Field 5 31 Mar 2017 - Matches Field 1 ... - 3
Field 6 01 Apr 2017 - Matches Field 1 ... - 2
Field 7 02 Apr 2017 - Matches Field 1 ... - 1
Field 8 03 Apr 2017 - Matches Field 1 ... - 0
All has been working fine but i have just noticed that if i put the following into Field 1 "31 mar 2017" ... the following dates are auto-populated but skips 26 Mar 2017 - after 25 and before 27
Field 1 31 mar 2017
Field 2 24 Mar 2017 - Saturday
Field 3 25 Mar 2017 - Sunday
Field 4 27 Mar 2017 - Monday
Field 5 28 Mar 2017 - Tuesday
Field 6 29 Mar 2017 - Wednesday
Field 7 30 Mar 2017 - Thursday
Field 8 31 Mar 2017 - Friday
The Javacript i am using is shown below
Line 6 - the number in bold, is changed per cell
i.e. FRIDAY
var strStart = this.getField("DateStart").value;
if(strStart.length)
var dateStart = util.scand("dd mmm yyyy",strStart);
var oneDay = 24 * 60 * 60 * 1000;
var dueMillis = dateStart.getTime() + -0 * oneDay;
var dueDate = new Date(dueMillis);
event.value = util.printd("dd mmm yyyy",dueDate);
else
event.value = "NA";
i.e. MONDAY
if(strStart.length)
var dueMillis = dateStart.getTime() + -4 * oneDay;
else
event.value = "NA";
2 things
1 - Thank you for an amazingly swift reply
2 - GENIUS!!!
Many many thanks!
Because of the change to day-time savings, which adds an extra hour on the 26th.
The solution is to change the code so that it adds a full day instead of a day calculated in milliseconds. So, for example, to add one day you would use this code:
dateStart.setDate(dateStart.getDate()+1);
var dueDate = new Date(dateStart.getTime());
2 things
2 - GENIUS!!!
Many many thanks!
Hello try67,
I appreciate your help but ...
I have tried but failed to implement your code into my PDF
What i actually did was change the number 24 to 23
It works for +1 and -1 hour on BST March and October as well as other dates
Not as "neat" as it could be but hey, it works
Can you confirm i am not being stupid please?
What didn't work with the code I provided?
Didn't know where to put it
Inside the curly brackets, replacing what you currently have... So for Friday it would be:
if (strStart.length) {
} else event.value = "NA";
By the way, I would put this code in a function and pass to it the number of days to add as a parameter, instead of writing out the exact same code for each day of the week, only with one minor difference. Will make implementing changes like this much more easy, too...
Hello try67,
To be honest you have kinda lost me ...
I have used the code you provided and it works a treat!
Coping and pasting the code into the other 6 cells and then adjusting the increment at the end of line 4 wasn't an issue
Maybe, if and when I go deeper into JavaScript it will make sense!
Once again, many thanks for you swift and helpful replies
Enjoy your weekend!
Rgds Mark
