Please someone:
How the heck do i retrieve/create a DEFAULT "automatic, always set" offset padding around every graphic/object frame and LINES in certain templates i use/create.
it's not case by case text wrap, it's a default setting around graphics/photo frames & lines. I don't know where they went, what to set (i know where the Window>Styles>Object Styles window is, i just don't know what settings are, if that's even where i do it.
It's not a standard one a a time text wrap, that much i know. indesignsecrets doesn't seem to know either and the results there are as imprecise and unhelpful as the adobe site, but what the heck? maybe an actual person knows.
I can't even find what the correct terminology is since the logical terms offset space around, bounding space around and padding around an object or frame don't seem to be involved.
sheesh. does it really have to be so complicated?
Please, and thank you.
If you want text wrap applied to all objects then set it with nothing selected. That will be you default going forward.
sheesh. omg. thank you!
for adobe: I still don't understand why there's not supplementary descriptive, logical (searchable) language such as mentioned above (and that I've seen others use to search for it too using those terms and path offset, for instance). you know, to make it logical and easier to find answers for.
Thanks again BobLevine!
May I recommend a good book?
InDesign CC: Visual QuickStart Guide (2014 release): Sandee Cohen: 9780133953565: Amazon.com: Books
This is a must have for anyone learning InDesign.
