Hello,
I've read through the developer guides and can't find any language about Data Merge exports.
What I'm looking to accomplish should be a rather simple script. The pieces I haven't been able to track down are in bold below.
1. Open file
2. Select Data Merge Source
3. For each
a. Toggle Data Merge
b. Save as InDesign file (name defined by column 1 in data merge underlying file)
c. Export to PDF (name defined by column 1 in data merge underlying file)
4. Next
5. Close file
// defines the csv file to use for dataMerge
var csvFile = File('filepath');
var exportLocation = File('filepath');
// opens InDesign template
app.open(File("filepath"));
//defines myDoc
var myDoc = app.activeDocument
// loads defined csv file as datamerge
app.activeDocument.dataMergeProperties.selectDataSource(csvFile,);
//runs loop
For each //datamerge record
//preview
//save as indesign
//export as pdf
Next
Would appreciate any help or thoughts on this. Thank you.
Sorry, i cannot help with the vbs side of scripting.
Perhaps you don't know, but one is able to execute vbs code with InDesign ExtendScript's doScript() method.
Search for doScript() in the forum here. Also see this post here where Excel is called by vbs using ExtendScript:
Re: How do you run VB from JSX and return a value?
Uwe
a moderator moved your question to the InDesign Scripting forum.
What is your InDesign version on what OS ?
Are you aware, that there is ExtendScript DOM documentation for nearly all InDesign versions?
Here one Gregor Fellenz compiled for CC 2017 12.0.0.81:
InDesign ExtendScript API (12.0)
Though, I don't think, that much changed the last years with datamerge.
See some references below or search the API documentation for "datamerge":
DataMergePreference
DataMergeOption
Uwe
Search the InDesign Scripting forum for datamerge.
One thread that came up with a search was:
It seems, that Preview is not scriptable by DOM objects directly.
And I remember that Preview should be avoided before a merge, because the function has a bug.
Also search for that in the InDesign forum.
FWIW: Maybe Preview for datamerge is scriptable by invoking the right menuAction in the UI, but as I mentioned above, this could perhaps spoil your merged results.
What do you exactly mean by: "toggle Data Merge Records" ?
Can you show some screenshots perhaps?
Do that with the forum's "Insert Image" control in the editor bar:
Uwe
Thank you for the insight on the DOM documentation. I am going to be writing this in vbs so I can get better integration with Excel, where all of the source data is pulling from.
I've realized I don't need to preview the datamerge, and rather need to utilize the Create Merged Document capability of InDesign, restricting to a Single Record in my For Each loop.
It seems there is a lot more documentation on jsx than vbs for things of this nature. Any direction on where to look for the datamerge option coding for vbs?
Here is what I would need it to do.
'sets InDesign
Set myInDesign = CreateObject("filepath")
'sets myDocument
Set myDocument = myInDesign.Open("filepath")
'loads defined csv file as datamerge
myDocument.dataMergeProperties.selectDataSource(csvFile,);
For Each [record in datamerge]
'create merged document on record i+1
unknown
'sets myDocument
Set dmDocument = myInDesign.activeDocument
'save as new filename
dmDocument.Save "filepath pulled from row 1 of datamerge"
export as pdf
dmDocument.Export idExportFormat.idPDFType, "filepath pulled from row 1 of datamerge",
False, myInDesign.PDFExportPresets.Item("[preset]")
Next
Again, big thanks for any tips or direction. Very appreciated.
Uwe
You can get all data from excel, as array, using this function Get data directly from Excel
