I have a send a SOAP request to an inDesign Server on MAC. When running larger jobs, the server is not terminated for the given timeout instead it throws exception after long time. I believe that the server is still running in the background producing the outputs.
The job set to 30 sec timeout and , this is the time line of the job starts and ended
begin : 16:30:53
Start job ...
java.net.SocketTimeoutException: Read timed out
Fail job...
14 minutes, 44 seconds.
End : 16:45:37
it almost took around 14 minutes, 44 seconds. to terminate the job.
the code snippt of the set timeout
Service inddService = new ServiceLocator();
ServiceStub ids = (ServiceStub) inddService.getService(new URL(url));
ids.setTimeout(30000);
Brahna
Hi Brahna,
Are you facing timeout issue for large jobs in InDesignServer CC2017?
In my workflow earlier we were using CC2015 and it processed large document in 4 hrs and there was no timeout happen and if I just replaced CC2015 with CC2017 then for same document a timeout happen after 10 mins.
Is there any change related to timeout b/w CC2015 and CC2017.
Also Is there any place where we can get the server sdk for CC2017 as prerelease site does not have it.?
Alam
