When I open the develop module all the images look like a negative.
I have seen on other discussions to go on to Preferences > Performance and uncheck Use graphics processor.
I don't have a performance tab under preferences. Working on a Mac with Lightroom 4.4. Thanks
GPU acceleration has been introduced with LR6.
Try to reset the color Profile of your Monitor to sRGB - for testing purpose only, since you should calibrate your monitor.
Thanks for your reply. I have checked the monitor. When i import the photos and they are in library they are fine. Its when i click the develop tab the photo changes
That is exactly why I told you to reset the color profile. Try it, and then post back.
I have tried but still have the same problem
Hi lkphotos,
There are multiple reasons why: bad monitor profile that causes Develop to render wrong usually with a color cast, bad GPU driver (turn off the GPU in Prefs / Performance) that probably causes Develop to render wrong, corrupted preview cache so the previews don't get updated, so Library is wrong, etc.
Sahil
Could you post a screenshot of your Develop module with the problem showing? Also, include the histogram in the shot.
Hal
