Hi All,
I'm using Animate CC to build an HTML5<canvas> final product.
Again, I'm still learning the terminology so I can do effectively search for answers. This one is eluding me:
How do I convert a string, like "myInstanceName" to something I can use (as the name of the instance) in a line of code like:
Thanks much!
an instance name is not a string so you can use it just like colin indicated.
but if you have a string, you would use:
this[myString].addEventListener('click',myFunction.bind(this));
Stage is perhaps not the same location as where myInstanceName is. This should work:
this.myInstanceName.addEventListener("click", myFunction.bind(this));
Yes, Kglad.
I do have a string and that "this[myString].addEventListener..." works.
Thanks much!
Thanks also, Colin.
you're welcome.
All there in the manual...
Thanks ClayUUID
good resource.
