I have LR 6.8.
Reverse geocoding option is missing under catalog setting.
How to make this option appears ?
Thank you for your answer.
When I use reverse geocoding with Lightroom 6.9 for a European country, or for Tel Aviv in Israel, reverse geocoding works. When I use it for towns in Palestine (like Ramallah) it is not working.
I observe the same thing.
It appears this limitation is a Google policy (Google provides the mapping for LR):
Status: Won't Fix (Intended Behavior)
Has been renamed to Address Lookup, and can also be paused/accessed over the Activity center (identity plate).
Basic setting should be in Catalog settings / Metadata.
Thank you for the answer.
In identity plate, adress lookup is "on". And in Catalog settings/Metadata position is also on.
But no suggestion for address, location, etc.
Have you another idea ?
Thanks.
What is the source of the GeoData/Coordinates?
Does it show in the correct format under GPS in the metadata panel?
Source of Geodata/coordinates is Map module of LR. This coordinates appear clearly.
GPS format is as you mention.
Hmm .. then it should fill in the fields above automatically.
First, try if it helps to update to the latest 2015.9: Download Photoshop Lightroom
If not, I'd try to reset the preferences: Resetting Preferences in Lightroom CC/6
In fact, I have LR 6.8.
I will re-install LR 6.8 and reset preferences as you recommend.
I keep you informed.
Thanks.
I suggest 6.9.
OK
I installed LR 6.9 and nothing has changed. Same problem.
I'm out of ideas .. if you have reset preferences and everything is activated it should just populate the fields after you drag and drop an image from the filmstrip to the map, given that you have an active internet connection.
Last thing to try: remove and reinstall LR: remove - reboot - install 6.0 - reboot - install 6.9 update.
It's what I did.
We have to stop and I haven't to "consume" your time.
Thank you for your help.
Last question : what do you think about plugin "Metadat Wrangler" from Jeffrey Friedl ?
Best regards.
Haven't worked with it, but used others from Jeffrey like the Geoencoding.
Hello,
to give a conclusion to our discussion,
the answer to the problem I have is not technical ... but political !!!!! Segregation ?
Thanks for your help.
Message du 28/03/17 08:50
De : "F. McLion"
A : "Claude ALEONARD"
Copie à :
Objet : Reverse geocoding
Reverse geocoding
created by F. McLion in Photoshop Lightroom - View the full discussion
If the reply above answers your question, please take a moment to mark this answer as correct by visiting: https://forums.adobe.com/message/9419406#9419406 and clicking ‘Correct’ below the answer
Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:
Please note that the Adobe Forums do not accept email attachments. If you want to embed an image in your message please visit the thread in the forum and click the camera icon: https://forums.adobe.com/message/9419406#9419406
To unsubscribe from this thread, please visit the message page at , click "Following" at the top right, & "Stop Following"
Start a new discussion in Photoshop Lightroom by email or at Adobe Community
For more information about maintaining your forum email notifications please go to https://forums.adobe.com/thread/1516624.
This email was sent by Adobe Community because you are a registered user.
You may unsubscribe instantly from Adobe Community, or adjust email frequency in your email preferences
As a practical matter, Adobe probably has little influence over this Google policy -- Google generally does what it wants to do regardless of customer desires. But you could file a bug report in the official Adobe feedback forum: Photoshop Lightroom | Photoshop Family Customer Community . (This forum is primarily user-to-user, in which Adobe product developers rarely participate.)
I consider the answer is « correct », but I cant’t find the « button » to click in the forum.
Regards.
Le 10 avr. 2017 à 23:57, johnrellis <forums_noreply@adobe.com> a écrit :
Reverse geocoding
created by johnrellis <https://forums.adobe.com/people/johnrellis> in Photoshop Lightroom - View the full discussion <https://forums.adobe.com/message/9446548#9446548>
It appears this limitation is a Google policy <https://issuetracker.google.com/issues/35829037> (Google provides the mapping for LR):
In disputed areas (http://en.wikipedia.org/wiki/List_of_territorial_disputes <https://www.google.com/url?q=http://en.wikipedia.org/wiki/List_of_territorial_disputes&sa=D&usg=AFQjCNGe_LDpC-aJZvSFu4rxmzzQWYRb4A>), geocoding results have no country (and sometimes no administrative_area_level_1). Reverse geocoding for disputed areas returns no results.
As a practical matter, Adobe probably has little influence over this Google policy -- Google generally does what it wants to do regardless of customer desires. But you could file a bug report in the official Adobe feedback forum: Photoshop Lightroom | Photoshop Family Customer Community <http://feedback.photoshop.com/photoshop_family/products/photoshop_family_photoshop_lightroom> . (This forum is primarily user-to-user, in which Adobe product developers rarely participate.)
If the reply above answers your question, please take a moment to mark this answer as correct by visiting: https://forums.adobe.com/message/9446548#9446548 and clicking ‘Correct’ below the answer
Please note that the Adobe Forums do not accept email attachments. If you want to embed an image in your message please visit the thread in the forum and click the camera icon: https://forums.adobe.com/message/9446548#9446548
Start a new discussion in Photoshop Lightroom by email <mailto:discussions-community-lightroom@adobe-v8.hosted.jivesoftware.com> or at Adobe Community <https://forums.adobe.com/choose-container.jspa?contentType=1&containerType=14&container=3316>
For more information about maintaining your forum email notifications please go to https://forums.adobe.com/thread/1516624 <https://forums.adobe.com/thread/1516624>.
You may unsubscribe <https://forums.adobe.com/unsubscribe.jspa?email=claude.aleonard%40orange.fr&token=e37ecf7d082f865835168f9e27d0d929df926099040276353683f5ecb1f789ea> instantly from Adobe Community, or adjust email frequency in your email preferences <https://forums.adobe.com/user-preferences!input.jspa>
