Hello all my question is just as stated in the Description. Hows come all the hidden layers display when previewing it? If i open the PDF it is only shows up with just the Cyan up in the top right but if i preview it shows everything. This worries a few of my clients they think stuff that is hidden will show up. HOw can i stop this from displaying (WITH CREATE ACROBAT LAYERS ON)?
Everything is hidden but it still displays in the actual PDF
Thank you
It's because you are viewing in Apple's Preview. For that feature to work you have to view in Acrobat 6 or later
Ok so there's no way to view it correctly with the Apple Preview?
Apple Preview cannot be relied upon for professional work. It's for quick and dirty PDF of emails and simple Word/Pages documents and such. There are many, many things needed for professional printing work, forms and interactivity that Preview doesn't handle properly.
This is also true for the PDF readers in web browsers.
The problem is not the front-end user using Apple Preview, it's customers and other end users. So, saying not to use it is not really an option. t should be understood that at this level, you are already using Acrobat and not a "quick and dirty" app to handle your files. You shouldn't be, anyways.
I don't understand what you're saying, "marcr96060040." There no one making people use a PDF reader inappropriately. It's just ignorance. There are a lot of people on a Mac who use Preview just because it's the installed default application to open a PDF file, and they don't know any better.
THis is the case with our client. I just made it simple and before sending the file to i move the hidden layers below all the layers i'm using Or if needed delete the hidden layers. That hides it from them and allows them to see the preview without the hidden layers showing.
That's not what I said. I don't know how you implied that. Yes. We know low-level programs/apps shouldn't be used in a design/creative setting. However, clients use what they are comfortable with. That can not be controlled and there should exist some easier workaround that does not require the designer to have to alter the original file.
Then we can agree to disagree.
Please look at what you're exporting. It is an Adobe PDF. Beyond Acrobat/Reader there is no assurance the PDF will work properly unless it's a plain vanilla, no special anything PDF.
This is not on Adobe so I suggest you point finger toward Cupertino. They have to be aware by now that their built in PDF viewer is pretty much garbage for advanced PDFs.
Hi Bob,
its a pretty basic PDF. Just a few pieces of art. but the art is in several different colors so i put different colored art on different layers on my template so that way i dont have to have 5 or 6 different templates. And maybe down the line i'll create a script that deletes the other non used layers.
Once you add layers it is not a basic PDF any longer.
I gotcha. Thank you. I'll just delete the unused layers or just drag the layer i'm using to the top of the list so that way its the only layer showing up.
