Linked text files with bullets
Mar 28, 2017 Mar 28, 2017
What do you know about linking and bringing in bulleted lists and tables? I'm having trouble on both when I have an existing bulleted list in Word and then place the linked file into indesign. I have the newest versions of both. Any help would be greatly appreciated.
A second question since you seem to be quite good with this.  I have some files that my team put together in Word. These files were not pre-formated with specific styles. Is there a best method to go through and simplify styles so they are consistent and then link to InDesign? (I hope that makes sense?)
349
Mar 29, 2017 Mar 29, 2017
Hi Natalie:
Bullets are an issue with linked files. If you have a bullet list defined as a Word style:
And you link it in InDesign with the corresponding Bullets style, it does this:
You have to select the bullet list and apply the style and clear overrides to fix it.
That's a lot of work if you have a lot of lists. I would prefer this workflow—create the Bullets Style in Word, but don't add bullets.
Then when you update, InDesign gets to add the bullets through its own style and you don't have the issue shown above.
As for your second question:
I don't have a better answer than to comb through both files, making sure that the style lists match exactly. Same spelling, same case, same spacing. I tend to be methodical in this practice. I would start of page one and match the Title tag in both applications, then the Byline tags, then the Body tags, then the Heading1 tags, the Heading2 tags, etc. When I get to the end of the document, I'm done.
Hope that helps!
Advocate ,
COuldnt we setup a glep code for that? If we now which character it bringing in, we could filter that and replace it right?
Bullets are done in InDesign with predefined paragraph style, no need for GREP here.
Advocate ,
Mar 30, 2017 Mar 30, 2017
Well i thought cause i see unsoprted characters (squares) we could make a GREP which replaces these for correct ones
