is there a way to automatically select preset "my-name" after click to "import"? (best will be select the last used preset)
And is there a way to automatically select "sort by capture time" in "import" screen? (It's sad for me it can be not part of preset.)
Jiri
Usually, it keeps the values selected with the last import.
Make sure LR has full access privileges to all folders needed by it.
Preference file and other file locations | Lightroom CC and 6
What is your OS?
Hi jiříp,
You can specify the import options, refer the below link.
How to specify import options in Lightroom
Mohit
1)
I am sorry. I was talking about "import preset".
I click "import". There is import preset "none". I select import preset "my-name". I import photos.
Next day I click "import". And there is again import preset "none". But I want to be last used import preset ("my-name") automatically.
2)
"sort by capture time" is not stored in import preset (it is not possible) but I want it always to by "sort by capture time" by default (not "none") - how to do it?
Thanks.
All these settings get set to own its own when you start using any presets, may be in your case Lightroom not saving the last action on the import screen.
You may try and reset the Lightroom preferences back to default and try using the presets after that.
Mohit
What is your OS?
