Correction du voile manquant
Mar 19, 2017 Mar 19, 2017
Bonjour,
J'ai récemment acheté la dernière version de "LIGHTROOM" 6.9.. Ce logiciel fonctionne très bien.
Mais, il me manque un "preset", "la correction du voile" J'ai voulu télécharger le preset "dehare" via internet, ce qui a planter mon logiciel.
J'ai du le réinstaller, heureusement sans perte de photos.
Pouvez vous me donner la marche a suivre pour cette installation. Ou pourquoi ce preset ne s'est pas installé.
Merci
3.2K
Community Expert , Mar 19, 2017 Mar 19, 2017
Dehaze is only included in the CC subscription version LR CC2015 and not in LR 6.
This might be interesting for you:
Lightroom 6 Dehaze – Cut through the fog
https://www.proloststore.com/products/dehaze
--- Got your issue resolved? Please label the response as 'Correct Answer' to help your fellow community members find a solution to similar problems. ---
Oui, j'ai déjà fait cette manipulation, cela m'a créé un plantage du logiciel.
Se que je trouve anormal, c'est que dans la "version abonnement" ce preset est inclus, mais pas dans la version Achat.
Je continue mes recherches. Merci de votre aide.
A bientôt.
What 'manipulation' did create what?
Dehaze is not a preset if you have a subscription and are using CC2015.
Having Dehaze as preset is the workaround to have it available in a perpetual licensed LR6.
Here's how it looks when you have a subscription:
Without a subscription, the slider 'Correction du voile' can't be made available.
Mar 29, 2017 Mar 29, 2017
Hi, I have a monthly subscription for Photoshop CC (2017) and Lightroom CC (2015) but the dehaze preset ("correction du voil" in french) is not available.
If I want to use it I have to open my raws with Camera Raw in Photoshop....
Make sure to use the correct email/AdobeID to log into LR and to have the process version set to 2012 (latest).
Thanks for your answer, I have the good log ID and the 2012 process version but no dehaze....
Check your version from the Help menu. Does it say CC 2015.9 (latest)?
Just in case you are lower than 2015.3 you need to update - suggested anyway.
Dehaze has been added in 2015.3.
Download Photoshop Lightroom
it says  version "CC 2015 [1014445]" and the creative cloud app says update is ok.....
CC app seems not to detect. Update manually to 2015.9 as mentioned.
