I am using Premiere Elements 10 and my project setting is is 1920 x 1080 p , 29.97. To date we have only been exporting as an mp4, either 720p or 1080p to upload to Vimeo and Youtube. Premiere even has a Vimeo preset. However, now we are lookin gto submit to platforms that require the following format:
Apple ProRes 422 HQ QuickTime .mov 1920x1080
Is it possible to export a file lformat ike this from Premiere Elements? I do not see this as an option in the share section?
I think you have to step up to Premier Pro, Final Cut Pro, Avid Media Composer, etc. to edit ProRes source files. However there is a sequence of choices that should get you to Quicktime output. I'm on version 15 and the interface is different, but I might be able to get you there. Basically, you are looking for menu choices in the Export and Share section.
Correct. Even if you get those menu choices from a more recent version of the Premiere software, that still might push me in the right direction.
Again, I don't know if you can edit ProRes footage.
The output dialog does have Quicktime choices. It should look a little like this. You may have to scroll down to see Quicktime as shown here:
Thanks for the screenshot! However my specs are 1920 x 1080 and your settings above say 720 x 480.
I have version 15 and the interface is different. So, I borrowed that screen shot from the internet somewhere to help point you in a direction. Do you see the "Advanced" button? Push it. It will lead you to other choices that will look something like this:
Okay cool. I will check out the advanced button to update the specs. Thanks for your help on this!
You are welcome. I hope it gets you where you want. I'm a bit blind when it comes to Apple things.
