Raw pinceau-Exposition ne fonctionne plus :(
Mar 28, 2017 Mar 28, 2017
Dans Raw avec le pinceau
Exposition qu’elle soit à droite ou à gauche le passage du pinceau éclairci
Donc plus possible d’assombrir
D’où vient ce problème ?
Merci
254
Explorer , Apr 01, 2017 Apr 01, 2017
Trouvé
Masquage en bas était coché
Find
Masking down was checked
Adobe
mfz56281847  wrote
In Raw with the brush
Show whether right or left the passage of the cleared brush
So it is no longer possible to darken
What is this problem?
Merci
The forum translator struggled with your post, and it is difficult to understand your question.  I'm guessing that you are talking about the local adjustment brush in Camera RAW which uses the shortcut 'K' and is indicated with the black arrow in the screen shot below.
If the brush is not functioning as you expect it to, check the settings at the bottom (highlighted in red) especially the Flow and Density.
If I am not interpreting your question correctly, the more information you provide in your post, the better the chance the translator will make sense of it.
The alternative is to use the French language forum
Forums en français
Bonne chance
Mar 29, 2017 Mar 29, 2017
Merci pour vos réponse, ci-joint 2 copies ecran
J'ai posté dans le forum en Français mais il n'y a pas de réponse
Merci pour votre aide
Thank you for your reply, enclosed 2 screenshots
I have posted to the forum in French but there is no reply
Thank you for your help
Mar 30, 2017 Mar 30, 2017
Faut-il réinstaller photoshop ?
Should I reinstall photoshop? (google translate)
Trouvé
Find
Enthusiast ,
Salut! Veuillez poster une capture d'écran de ce que vous essayez de faire.
