I made presentation slides in Indesign and added page transitions. Then I exported the file as an Interactive PDF. When I open the file in Adobe Acrobat it looks fine, but as soon as I transition to the next page the entire slide becomes blurry. Both text and images are not sharp. The difference is very clear between the file upon opening and once the pages transition. Unfortunately the 'Export to Interactive PDF' dialog does not provide many options.
Any thoughts on why this is happening?
Thanks a lot!
Can you take a screenshot of the problem?
Hi John Mensinger,
Yes, I can. I've attached screenshots of a slide, left is upon opening the pdf and right is once the page has been transitioned.
Okay, that doesn't necessarily look like an egregious malfunction or anything, but I do see the difference. Honestly, I don't have a lot of experience with Acrobat page transitions, but it seems believable that once transitioning is active, the rendering engine might assume a different mode of operation (anti-aliasing) than it runs while displaying static pages of vector-based content.
A couple things you could try:
