Creating a counter in HTML5
Mar 29, 2017 Mar 29, 2017
Hi all,
We're trying to create a simple counter in HTML5, but all I find online is AS3...
We need the numbers to go from 10.000 -> 50.000
Is it possible?
Thanks for your help!
2.8K
Community Expert , Mar 29, 2017 Mar 29, 2017
var start = 10000;
var end = 50000;
var current = start;
var f = tickerF.bind(this)
createjs.Ticker.addEventListener('tick',f);
function tickerF(){
this.your_tf.text = current;
current++;
if(current>end){
createjs.Ticker.removeEventListener('tick',f);
you want something that you click (up or down) to increment or decrement a display?
No, just the running numbers automatically
what are "..running numbers.."?
do you want something that displays numbers incrementing from 10,000 to 50,000 over some time period?
Haha exactly
Thank you for your help!
var start = 10000;
var end = 50000;
function tickerF(){
current++;
if(current>end){
THANK YOU !!!
Is there a way to control the speed? To make it go faster?
you're welcome.
you can increase your framerate:
Ticker.framerate = 60;
or you can increment by 2's or 3's etc
As always, directly tweaking Ticker.framerate is not advisable because that overrides the frame rate set in the publish settings.
Mar 31, 2017 Mar 31, 2017
Thank you kglad - your code really helped.
BTW we were able to control the speed by changing the:
current++; to current = current+7; (could be any number)
you're welcome.
Jul 15, 2022 Jul 15, 2022
Hi, thank you for your code, is there a way to set the speed by second using this code? or there is a spesicif number per second? thanks in advance.
May 02, 2023 May 02, 2023
@Nurhamida25024381d3rg
yes. use setInterval instead of ticker.
@Jonathan22259649im63
yes, use setInterval and adjust the interval.
Oct 07, 2017 Oct 07, 2017
Hi kglad,
I'm trying to use your counter in a a animate CC project using gsap. The counter works fine, but I need to be able to delay the starttime for the counter, as I want it to sync with an animation. Is this possible? Thx
add the listener when you want the timer to start.
So easy when you know how Thanks a lot!
Oct 08, 2017 Oct 08, 2017
Sorry - me again. Is there a way to use the counter twice (e.g. reset it and run it again). Thx so much for your help
call startTickerF whenever you want to start the ticker:
var start;
var end:
var f =tickerF.bind(this);
var current;
startTickerF(10000,50000);  // edit this line to adjust for your start and stop numbers
function startTickerF(startNum,endNum){
start= startNum;
end = endNum;
current = start;
function tickerF(){
this.your_tf.text = current;  // do whatever with your current number
current++;
if(current>end){
Thank you sp much. When adding the code, the project won't run. However, if I remove the line "startTicker(10000,50000);  // edit this line to adjust for your start and stop numbers", the project runs, but counter doesn't work. Any thoughts? Thx
there's a typo.  that should be
That did the trick. Thank you!
you're welcome.
(p.s when using the adobe forums, please mark helpful/correct responses, if there are any.)
Hello, I come to you after seeing this answer which was very useful to me.
I would like to know if it was possible to have an Ease on the counter animation?
Thanks in advance
