quote:
None that are as simple as writing it to a disk first. As Adam mentioned, you also delete the file right after you use it.
Just out of curiousity, what is your objection to this approach?
quote:
Originally posted by: Dan Bracuk
slightly different, write it to a file and use cfinclude to execute it.
quote:
True. Let me rephrase -- is there any way to execute it that doesn't involve writing it to disk first?
-Josh
quote:
Originally posted by: Newsgroup User
you should be able to use
a mix of evaluate() and de() [delay evaluate] to execute code in a string.
quote:
Invalid CFML construct found on line 1 at column 1.
ColdFusion was looking at the following text:
The CFML compiler was processing:
< marks the beginning of a ColdFusion tag.Did you mean LT or LTE?
