I'm trying to change the grey text and highlights stark white in this UI without effect the rest of the image to much.I've tried select a color without much luck.It's the text and Icons that's difficult to select well.
Any suggestion are greatly appreciated.
Hey! Do you require something like this? I did this by adjusting curves and adding more light to it. Thereby giving me a lighter shade of grey.Or else if you have a vector file for this you can change the color of shapes individually in illustrator easily.
Thanks Bahaar Khan,
I'm sorry that it took me so long to respond.
I only want to whiten the grey text without lightening the rest of the image.
Thanks for your input.I see that my original question didn't indicate that very clearly.I want to keep the other colors unchanged.It would probably be easier to mask and add white text.The Icons create another challenge altogether.
