presenter add-in
Sep 04, 2008 Sep 04, 2008
I installed presenter today and in powerpoint 2007 the add-in doesn't show up.
Presenter
3.5K
Participant ,
You may try following steps , it may help
PowerPoint 2007
Click PowerPoint Office Button > PowerPoint Options > Add-ins.
Click the Manage menu, select Disabled Items, and then click Go.
In the Disabled Items dialog box, click the Presenter add-in, and then click Enable.
Click Close.
or/and
Click the Manage menu, select COM Add-ins, and then click Go.
In the COM Add-ins dialog box,check "Adobe Presenter PowerPoint COM Addin "
Click OK.
After making these changes , make sure to close PowerPoint and Open it again .
Found these steps at http://kb.adobe.com/selfservice/viewContent.do?externalId=kb403553&sliceId=1
I hope this helps
-Leo
leo_leo,
thanks for your quick reply.
there should be a .DLL file
but in my case, although Presenter is installed
it is not in the COM add-in dialog box
can somebody tell me what .DLL and where tot find it
Participant ,
Yes , there is a menulauncher.dll at installed location
Sep 05, 2008 Sep 05, 2008
leo_leo
sorry for reacting a little later
like you suggested i did the following
In the COM Add-ins dialog box,check "Adobe Presenter PowerPoint COM Addin " => here my screen simply gives the following text in dutch -> COM ADD-ins
there is no list
so i do add
i can find in my list the menulauncher.dll
i select it and i Click OK.
i receive the COM ADD-ins - screen again
there is no list nor item in it
and so presenter can not be launched
Participant ,
Sep 06, 2008 Sep 06, 2008
Did you try uninstalling Presenter and then installing it again ?
Sep 08, 2008 Sep 08, 2008
yes,
i unstalled acrobat and presenter
i even migrated this weekend from cs2 to cs3 - since i only had acrobat 7 on this machine
the final result = 0
frustrating...
Sep 15, 2008 Sep 15, 2008
I'm experiencing the same problem running under Vista Ultimate SP1. I've gone in and tried to manually add the menulauncher.dll, install/uninstall/reinstall with same results.
Sep 21, 2008 Sep 21, 2008
This may work for your situation,
(1) While presenter is still installed , copy menulauncher.dll from the the installed program folder for presenter , then past it into the default folder for PowerPoint add-ins...
(2) Open PowerPoint as administrator, then navigate to its COM add-ins menu, when you click add, then it should open the default folder for PowerPoint add-ins with the menulauncher.dll file you copied in it. click the file to add it. should populate as a add-on. close PowerPoint.
(3) uninstall presenter. restart computer. reinstall presenter. after install it should launch PowerPoint to show the presenter tutorial (getting started file). The presenter tab should now be visible
hope this helps, it was performed with vista premium
(4) also, after you see the presenter tab .... Go to the COM add-ins and then have it point to the menulauncher.dll that is located in the program folder for presenter by clicking add then navigating to that folder (this would allow presenter to function properly).
Oct 18, 2008 Oct 18, 2008
I have followed all these instructions several times to no avail. I am on Vista Ultimate 64bit running Office 2007. I have tried every bullet point in the suggestions. Has anyone got presenter to work on 64Bit Vista?
thanks.
Oct 23, 2008 Oct 23, 2008
Thanks for the its much appreciated
Help resources
