I am running Lightroom CC2015 on an iMac and a Mac Book Pro (both w/recent updates). On the Mac book, the adjustment brush has a preset for "Milky Way" and "Darken Upper Sky" that I can't seem to find on the iMac desktop version. Anyone have a similar issue of solution? Thank you!! !
Hi LiHotShots,
<Edit>Could you check the preset name installed on your Mac Book Pro and check of the same is available online? Lightroom comes with few default presets? You can migrate all your user presets following this article https://www.lightroompresets.com/blogs/pretty-presets-blog/10550321-3-steps-to-transfer-your-pretty-presets-to-a-new-com…
Let us know if that helps.
Akash
Hi LiHotShots,
<Edit>Could you check the preset name installed on your Mac Book Pro and check of the same is available online? Lightroom comes with few default presets? You can migrate all your user presets following this article https://www.lightroompresets.com/blogs/pretty-presets-blog/10550321-3-steps-to-transfer-your-pretty-...
Akash
Neither of these were supplied by Adobe. So, you've either created/named them yourself or downloaded them from a third party. Fortunately, you can copy them another computer relatively easily.
Where did these presets come from? Did you save them yourself on the laptop?
To go to the folder where they are stored, go into Preferences, Presets, Show Lightroom Presets Folder and look for a subfolder called Local Adjustment Presets. You can copy presets to the corresponding folder on the other computer.
