would like to know if anyone using the lens profile for Laowa 15 mm Macro Wide lens in lightroom! It use to be in the profile options, I use it for a longtime! now after update LR there only Laowa 60 mm & 105 mm in the profile options...
would like know if any had this problem.
Hi Azurrum ,
The only two supported Laowa lenses in Lightroom are the 60 and the 105 mm. Please refer Work with lens profiles in Adobe Photoshop, Lightroom, and Camera Raw and try creating your own lens profile or check Digital Negative (DNG), Adobe DNG Converter | Adobe Photoshop CC (Lens profile downloader)
Akash
Hi Azurrum ,
Akash
Hi Akash! Thanks for your response.
as I wrote I have used that Lens profile in LR!
have hundreds of photos to show this.
have tried to make a Lens Profile... very difficult program to handle
Thank you Akash
Was it on the same computer and on a previous version?
Lens profiles are saved on location:-
Windows:-
C:\Users\[your username]\AppData\Roaming\Adobe\CameraRaw\LensProfiles\1.0\Downloaded
On a Mac:-
Macintosh HD / Users / [your username] / Library / Application Support / Adobe / CameraRaw / LensProfiles /
Akash
HI! sorry but there is no C:\Users\[your username]\AppData\Roaming\Adobe\CameraRaw\LensProfiles\1.0\Downloaded
om my computer
Navigate to this folder.Do not copy paste in the address bar in explorer. You'll see your username in under Users folder and then rest of the path is same.
Note that you must allow hidden files to show up as the "appdata" folder is hidden.
Akash
Hi! I belive you about it's not supported in LR at this moment... but it use to be before update!
and the support should have callad me days ago... never heard from any support.. this was about a doffrent problem that came with the update..
