I am using AS3 in Flash Professional CS5.5
i get these errors when I put my "boxMC" into the background of "WorldMC". it works not how i want it when i put put boxMC on my main stage. When i do so it only traces for that one boxMC not the ones that are spawning inside of WorldMC.
Here are my errors:
1067: Implicit coercion of a value of type Array to an unrelated type tankscript.turrent:Box. 1180: Call to a possibly undefined method Box. 1061: Call to a possibly undefined method push through a reference with static type tankscript.turrent:Box 1119: Access of possibly undefined property length through a reference with static type tankscript.turrent:Box. |
Here is my code that is having the issues.
var boxMC:Array;
WorldMC.boxMC = new Array();
// -----Box Spawning------
//only spawn a box if there are less tan 100 already on screen
if(WorldMC.numChildren<10)
// Make a new instance of the box class
var bx = new Box();
// add the box to the display list
WorldMC.addChild(bx);
//position and rotate the Box;
bx.x = Math.random() * -1100;
bx.y = Math.random() * 1;
bx.rotation = 40;
// add the box to list of box
WorldMC.boxMC.push(bx);
//trace the length of the array
trace(WorldMC.boxMC.length);
This line:
should be:
while(WorldMC.numChildren<10)
your first line of code does nothing but add confusion and your notation is going to add to your confusion. ie, if you like to use MC to indicate a movieclip, don't use that to indicate an array, too.
anyway, those don't explain the errors. the first error message would be expected if you have something like:
WorldMC.boxMC=bx
but i don't see that in the code you posted so i suspect you're failing to display enough info to help you.
to remedy, click file>publish settings and tick 'permit debugging'. retest.
the problematic lines of code will be in the error messages allowing you to pinpoint the problems. start with the first error and fix it. then work on the next etc.
In publishing settings you can check a box that enables debugging. If you do that you'll also get the line number where the problem is happening.
Why do you have the array inside the container movieclip? I would change these lines:
var boxMC:Array = new Array();
boxMC.push(bx);
trace(boxMC.length);
I have 3 classes set up to run my game one for the turrent to shoot my bullet, one for my bullet, and one for my Box
This is my Box class code:
package tankscript.turrent
// import any necessary files/libaries
import flash.display.MovieClip;
import flash.events.Event;
import flash.geom.Point;
public class Box extends MovieClip
private var boxSpeed:int;
private var target:Point;
function Box()
// constructor code
boxSpeed = 10;
trace("Made a Box!");
//Set target location of the ship
target = new Point();
target.x = Math.random() * 2500;
target.y = Math.random() * 0;
// add an event lsitener to update every frame
addEventListener(Event.ENTER_FRAME, update);
function update(e:Event)
// point the box at the target
var dx = target.x - x;
var dy = target.y - y;
var angle = Math.atan2(dy,dx) / Math.PI * 180;
rotation = angle;
// move in direction of the box is facing
x=x+Math.cos(rotation/180*Math.PI)*boxSpeed;
y=y+Math.sin(rotation/180*Math.PI)*boxSpeed;
// Calculate the distance to target
var hyp = Math.sqrt((dx*dx)+(dy*dy));
// if the hyp is less than 5 pixels, pick a new target
if (hyp <5)
This is my main game code:
import flash.events.KeyboardEvent;
import flash.ui.Keyboard;
import flash.display.Stage;
tankMC.gotoAndStop("TankStandStill");
var rightPressed:Boolean = new Boolean(false);
var leftPressed:Boolean = new Boolean(false);
var tankSpeed:Number = 15;
var turrentSpeed:Number = 15;
var boxSpeed:Number = 10;
stage.addEventListener(KeyboardEvent.KEY_DOWN, keyDownHandler);
stage.addEventListener(KeyboardEvent.KEY_UP, keyUpHandler);
stage.addEventListener(Event.ENTER_FRAME, gameLoop);
function keyDownHandler(keyEvent:KeyboardEvent):void
if (keyEvent.keyCode == Keyboard.RIGHT)
rightPressed = true;
else if (keyEvent.keyCode == Keyboard.LEFT)
leftPressed = true;
function keyUpHandler(keyEvent:KeyboardEvent):void
rightPressed = false;
leftPressed = false;
tankMC.gotoAndStop("Tank Stand Still Left");
function gameLoop(loopEvent:Event):void
//Tank move
if (rightPressed)
if (tankMC.x < 1000)
tankMC.x += tankSpeed;
else if (WorldMC.x > -1050)
WorldMC.x -= tankSpeed;
tankMC.gotoAndStop("Tank MovingRarrow");
if (leftPressed)
if (tankMC.x > 700)
tankMC.x -= tankSpeed;
else if (WorldMC.x < 900)
WorldMC.x += tankSpeed;
tankMC.gotoAndStop("TankMovingLeft");
//Turrent move
if (rightPressed)
if (turrentMC.x < 940)
turrentMC.x += turrentSpeed;
WorldMC.x -= turrentSpeed;
if (leftPressed)
if (turrentMC.x > 640)
turrentMC.x -= turrentSpeed;
WorldMC.x += turrentSpeed;
var boxMC:Array;
// Variables etc
// -----Box Spawning------------
var bx = new Box();
bx.rotation = 40;
what's the point of posting all that?
did you read either response to your first post?
var boxMC:Array;
// Variables etc
var bx = new Box();
bx.rotation = 40;
boxMC.push(bx);
i fixed it and now it says:
"Box" is my class
import your Box class.
Would you have an idea on my its only tracing 1 boxMC instead of the 10 im trying to count? it says "Made a Box! 1 Made a Box! 1" and and over until it hits 10 times. im trying to get the number 1 to go up to count the 10 boxMC im trying to count
on why its only*
This line:
should be:
Oh that worked! Thank you very much
"Turret".
Not "turrent".
I was going to comment on that, but it wouldn't break the code, unless the actual folder is named 'turret'.
While the code doesn't care, there's a chance it would have ended up in UI text like that too, given the consistent nature of the misspelling.
I noticed my misspelling of that word a bit after i started my coding and decided to just play it safe and not to to go about and fix the wording
I have a different class for making my bullet shoot out of my turrent. But i need to make my bullet spawn on to my "WorldMC". Like i have the box spawning on it. but since i have my code in a class i cant seem to do "WorldMC.addChild(b)" i get an error saying "Access of undefined property WorldMC" do i need to import something? if so how would that code go?
import flash.events.MouseEvent;
public class Turrent extends MovieClip
var shotCooldown:int;
const MAX_COOLDOWN = 10;
public function Turrent()
// constructor code
// set the shot cooldown
shotCooldown = MAX_COOLDOWN;
// add an event listener to update the turrent every frame
// set up an event listener for when the turrent is added to the stage
addEventListener(Event.ADDED_TO_STAGE, initialise);
function initialise(e:Event)
// add an click Listener to the stage
stage.addEventListener(MouseEvent.CLICK, fire);
function fire(m:MouseEvent)
trace("Fired!");
//if we're allowed to shoot
if (shotCooldown<=0)
// reset the cooldown
//spawn a bullet
var b = new Bullet();
// set the position and roation of the bullet
b.rotation = rotation;
b.x = x;
b.y = y;
parent.addChild(b);
// play firing animation
play();
// reduce the shot cooldown by 1
shotCooldown--;
//Make the turrent face the mouse
if (parent != null)
var dx = parent.mouseX - x;
var dy = parent.mouseY - y;
var angle = (Math.atan2(dy,dx)/Math.PI*180);
rotation = angle;
Your code doesn't include WorldMC.addChild(b), you're using parent.addChild(b), which ought to work.
Are you getting any errors, or bullets not appearing?
How everything is at the moment it works, but i'm about to put a hit test object in my code but the code wont work if my boxs and bullets are on two different areas. Unless i'm mistaken
There is hitTestPoint(), where you could test any point value to see if it hit an object. Here's a discussion about whether to use hittestobject or hittestpoint for the case of bullets:
actionscript 3 - AS3: hitTestObject vs hitTestPoint for Bullet vs Enemy - Stack Overflow
I would use it, but that is at a point my boxes are moving. Im not sure how well it would work
