Hi
For a task I would need the image dimensions exported from Lightroom.
For example:
the image orignal (or cropped) dimensions are 6000x4000 Pixels.
then the image is exported with 1500x1000 Pixels.
I need the 6000x4000 Pixels somehow exported in Metadata
workarounds like, for example, the info is included in a special field or added at the end of the description field are fine too.
thanks for help
The Metadata Wrangler plugin lets you insert the original (uncropped) height and width into the caption, title, or a number of other fields when you export a photo.
When the new JPG file is created from your edits, Lightroom does not record in the EXIF data what the original file size was.
You could include the image size in the title of the exported photo, or create a folder whose name is the image size
thanks for all your inputs.
the plugin really was doing the task - great.
