Save as jpg, containing selected layer name
Engaged ,
Apr 01, 2017 Apr 01, 2017
Hello, greetings to all!
1- I open a document,
2- I Perform an action to set the color, size, and print type setting
3- I Merge all layers of the document, and rename it to: Print_A4-MD
4- Now I need to create a backup of this configured document for future impressions.
The first 3 steps I can perfectly with actions I recorded:
So I found a form that I like a lot:
When I select the "Print_A4-MD" layer and execute a Script, I save in the same directory a file named Print_A4-MD.jpg, containing the name of the selected layer.
My question is:
How to modify the script to save Print_A4-MD_01.jpg, Print_A4-MD_02.jpg, Print_A4-MD_03.jpg ..... whenever I re-run this script on the same selected layer ?? Thank you.
Here is the script for review:
// saves jpg into same folder;
// be advised: this  overwrites existing jpgs of the same name without prompting.
// 2010, use it at your own risk;
#target photoshop;
if (app.documents.length > 0) {
var thedoc = app.activeDocument;
// getting the name and location;
var docName = thedoc.name;
if (docName.indexOf(".") != -1) {var basename = docName.match(/(.*)\.[^\.]+$/)[1]}
else {var basename = docName};
// getting the location, if unsaved save to desktop;
try {var docPath = thedoc.path}
catch (e) {var docPath = "~/Desktop"};
// jpg options;
var jpegOptions = new JPEGSaveOptions();
jpegOptions.quality = 9;
jpegOptions.embedColorProfile = true;
jpegOptions.matte = MatteType.NONE;
//save jpg as a copy:
thedoc.saveAs((new File(docPath+'/'+thedoc.activeLayer.name+'.jpg')),jpegOptions,true);
//that’s it; thanks to xbytor;
Actions and scripting
773
Advocate , Apr 01, 2017 Apr 01, 2017
There you go.
(function() {
    try {
        #target photoshop;
            var basename = docName;
            var docPath = "~/Desktop";
            try {
Adobe
Advocate ,
There you go.
(function() {
    try {
        #target photoshop;
            try {
                docPath = thedoc.path;
            } catch (e) {}
            // jpg options;
            var saveFile = docPath + '/' + thedoc.activeLayer.name + '.jpg';
            if (File(saveFile).exists)
                saveFile = incrementFile(saveFile);
            thedoc.saveAs(new File(saveFile), jpegOptions, true);
        function incrementFile(pathToFile) {
            var saveSufixLength = 2,
                suffix = zeroPad(0, saveSufixLength),
                newPathToFile = pathToFile,
                suffixInteger, folder, fileName, extension;
            while (File(newPathToFile).exists) {
                suffixInteger = parseInt(suffix, 10);
                suffixInteger += 1;
                suffix = zeroPad(suffixInteger, saveSufixLength);
                folder = File(pathToFile).path;
                fileName = File(pathToFile).name.substring(0, File(pathToFile).name.lastIndexOf("."));
                extension = File(pathToFile).name.substring(File(pathToFile).name.lastIndexOf(".") + 1, File(pathToFile).name.length);
                newPathToFile = folder + "/" + fileName + "_" + suffix + "." + extension;
            return newPathToFile;
            function zeroPad(num, digit) {
                var tmp = num.toString();
                while (tmp.length < digit) {
                    tmp = "0" + tmp;
                return tmp;
    } catch (e) {
        alert(e.toString() + "\nScript File: " + File.decode(e.fileName).replace(/^.*[\|\/]/, '') +
            "\nFunction: " + arguments.callee.name +
            "\nError on Line: " + e.line.toString())
Engaged ,
It worked perfect! Forever grateful to you. I see almost all posts in this forum and I realize that you "Tomas Sinkunas " has collaborated very efficiently and helped a lot. Many thanks for the great help and congratulations for the work on After Efects.
www.rendertom.com
Advocate ,
Thanks buddy.
