I want to modify the book marks in my pdf. How can I write a code in JSCript for that ?
For example when I Ctrl + J and try to run this code:
var bkm = this.bookmarkRoot.children[0];
console.println( "Top-level bookmark name: " + bkm.name );
It says :
ReferenceError: bkm is not defined
1:Console:Exec
undefined
Thanks for your kind assistance.
Message was edited by: JSM (Discussion successfully moved from The Lounge to Editing & Exporting PDFs)
You need to select (with the mouse or the keyboard) the entire code before
executing it.
On Sun, Apr 2, 2017 at 12:18 PM, Just Shoot Me <forums_noreply@adobe.com>
executing it.
Sometimes when I select the entire code and press enter it executes and some time with the same code, the code just disappears ?
Any idea why this is happening ?
Not really, no... What code are you executing? What key are you pressing?
... and, are you using a Mac or a Windows system?
This tutorial explains which keys to press in order to execute code in the console window: https://acrobatusers.com/tutorials/javascript_console
Ok. Yes. I mananged that some how. But some how this code does not work. Any idea why ?
function ZBookmark(bkm, nLevel)
for (var i = 0; i < nLevel; i++);
bkm.zoom = 1;
if (bkm.children != null)
for (var i = 0; i < bkm.children.length; i++)
ZBookmark(bkm.children, nLevel + 1);
console.clear(); console.show();
console.println("Setting Zoom Level");
ZBookmar(this.bookmarkRoot, 0);
What makes you think that Bookmark objects have a "zoom" property?
The following line makes no sense:
Bookmarks doesn't have a property with the name "zoom"
bkm.zoom = 1;
Not all bookmarks are link with go to a page view with a specific zoom.
Bookmarks can could be a link to a web page, run some custom JavaScript, open a destination, etc.
One cannot access the action associated with a specific bookmark in JavaScript so it might not be possible to add the zoom setting to a specific bookmark.
If what you're trying to do is change the Zoom Level associated with your bookmark then you should know it's not possible to do it with a script. It requires using a stand-alone tool (like this one I've developed: Custom-made Adobe Scripts: Batch Edit Zoom Level in Bookmarks) or possibly a plugin.
