Hi all : Got the full suite a few months ago, running Photoshop and ligthroom on my laptop all the time, but today Photoshop won't run once I strat it will tell me that a problem caused to stop, running on win 10, I have uninstalled 2 times and don't work does work fine in my desktop, any Ideas?
Mariano
Hi you should change the DLL name in your system then all default path will change, then restart PS it's work fine. Try this
How i change dll
Sent from my iPhone
hi could u explain little bit more ?
Hi Mariano,
Please try steps below:-
Could you try steps mentioned in this Article Photoshop CC 2015 crashes on launch or exit | Windows
Let us know if that helps.
Akash
hi, i have tried your method but still same problem goes on.
my uptades are up and everything and other cc programme are run as stable
Hi gokayg,
May I know if you are facing the same issue and getting the same error message as Mariano?
Akash
hi
i ve solved my problem by accidentally
there was a strange programme occur on my hidden icons that i did not installed. so i delete it and ps run with stable.
everthing is ok now.
so for whom want to know programme name is web companion made by lavasoft, some kind of anti spyware
Wont work i do have Ps 2017 It loads , Akash it try to load get to main screen( never load the welcome page) and then message that encounter a problem and need to stop working and need to close and then window looking for solution etc
Hi marianos,
That indicates that there is a problem with your GPU driver. Please take a look at this article Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues and let us know if that helps.
Akash
Not is not working.still did upgrade all lenovo drivers, wonder if i delete the cloud and start again will help? is there any chat from Adobe that you can do a wedex?
Hi Mariano,
You can get in touch with our Technical Support team. See Contact Customer Care
Akash
