I posted this question here: Poetry book text formatting
I'm currently working on a poetry book layout and I came up with this struggle:
I have some long lines that don't fit in a single line and (without changing paragraph) and I'd like to have all of those extra lines automatically being right justified.
I tried using nested line style, but I only manage to apply a different Character Style (not a paragraph one) on the second line.
Is there a way to achieve what I need without having to manually format every "exceeding line"?
To say it in other words I need to have all lines longer than the text box right justified.
I hope I was clear enough (if not sorry, english is not my mother tongue).
User DBLjan suggested me to try with a script: "Find out which paragraph exceeds the textframe. Scripters can tell you, if theres a value for this, or if you have to find out the hard way: Compare first characters baseline y with the last character baseline y. If they differs, your line exceeds the textframe – now the script could apply another paragraph style for the right alignment", but I'm totally noob in scripting and I have no idea where to start...
Can anybody help?
Edit: See picture for a reference
You can't have part of a paragraph right aligned and part left even if there on separate lines so you have to either add a right tab or separate them into separate paragraphs.
The below add the tabs
HTH
Trevor
var sel, story, paragraphs, paragraph, characterStyle, n;
sel = app.selection[0];
if (!sel || !sel.properties.baseline) {
alert('No text Selection!');
exit();
// change LongLine to the name of the style you want
characterStyle = app.activeDocument.characterStyles.itemByName('LongLine');
characterStyle = characterStyle.isValid && characterStyle;
story = sel.parentStory;
paragraphs = story.paragraphs.everyItem().getElements();
n = paragraphs.length;
while(n--){
paragraph = paragraphs
; if (paragraph.lines.length > 1){
paragraph.lines.itemByRange(1,-1).insertionPoints[0].contents = SpecialCharacters.RIGHT_INDENT_TAB;
if (characterStyle) {
paragraph.lines.itemByRange(1,-1).appliedCharacterStyle = characterStyle;
Hi Trevor,
The op wants to "right-align" the 2nd part of the poetry double-line (the para has a left-alignment).
Surely a same applied para style through the doc and I suppose in all the doc (maybe several stories …)!
