Bonjours à tous,
alors voilà, je ne trouve pas le moyen d'aligner une signature en fin de texte, qui s'ailigne à droite alors que sur la même ligne il y a un paragraphe aligner à gauche...
j'ai tout le paragraphe qui vient avec moi, je suis entrain de péter und durite !!!
Merci d'avance !
Change the space in front of the signature to a Right Indent Tab.
Use Shift Tab or
Hi hugoblaz,
Could you please confirm if you are trying to align the signature you added to PDF.
If you are adding the digital signature, then it is not possible to align the field in Adobe Reader.
If you are referring to something else, please let us know.
It will be helpful if you can share the screenshot of the PDF, it will help us to understand better.
Also, share the name and dot version of Adobe application you are using.
Meenakshi
Im not talking about PDF but the problem is on inDesign:
I want that the signature goes to align on the right but i can't beacause de paragraph is align to left... did you have a solution ??
Moving this thread to InDesign
Use Shift Tab or
Yes ! Beatiful !! Thank you
De rien!
