Can the version of photoshop (32-bit CS5 - 64-bit CS5) change the result of a script?
The same script on 2 pc with Windows 7 pro, produces 2 different results; A good and a bad!
I can not understand why ?!
Which code?
What is the difference in the result?
As pixxxel schubser mentioned, it's hard to know without know what it's doing or what the code is. However, you can get different results if your script doesn't set preferences for what you're doing, and it defaults to whatever that computer is set at. For example, if you have a script that adds lines of text using the DOM, if the leading has been altered on one computer, it will stay that way and mess up your line spacing with your script.
