Is that clear, what to do..
A
Not clear at all. Please explain the problem in detail.
Not clear at all. What version of Lightroom (exact version) are you using? What operating system? What is it exactly you want to do? Have you looked at the sort order after you have imported your images? You control that in the library module. The more information you can provide about what you have and what you're trying to do, the more likely it is that you'll get the help that you are seeking.
simple date order after import, ls 6.9. osx 11
The brevity of your posts, and the lack of writing complete sentences, does not usually lead to a quality answer.
If you're not going to describe the problem in more detail, it's hard to help.
As said before Set the Sort: to Capture Time. Very simple.
Set the Sort: to Capture Time. Images will be in order.
