The filmstrip somehow became oversized, and I am unable to find an edge to grab to make it smaller. I tried deleting the LR preferences from the library in my Mac, restarting the computer and then opening LR. I delete the file com.adobe.lightroom6.plist, but it reappears after I open LR again, and the problem continues. I also tried restoring preferences, but I still have the issue. I'm running Sierra 10.12.4, which was recently updated, but I've had the problem for a couple of weeks, since before the update. I took a screen shot, but I'm not sure how to attach it here.
Meanwhile, please add your me-too vote and details of your issue to the bug report in the official Adobe feedback forum: Lightroom: Filmstrip is covering / overlapping filter- and breadcrumb bar | Photoshop Family Customer Community . Even though support says an update is coming out that will fix the problem, Adobe customer support is notoriously unreliable, so personally I wouldn't attach high confidence to that statement. There are a few user-interface bugs that Adobe thought was fixed in th
...Copy link to clipboard
Try the answer given at- Filmstrip in Lightroom CC overlaps and cannot be reduced
I tried all of the suggestions in that link. None of them work. Every time I reopen LR, and turn on the filmstrip, it overlaps. Any other suggestions?
Just guessing at answers really!-
Toggle panel views: F6 (function key 6), [Shift+Tab], also Tool bar
Minimize the entire Lr window and re-size.
And are you running v6.9 CC2015.9 ?
Yes, 6.9 CC2015.9. This is hugely frustrating! None of the suggestions above or in the couple of links about the issue seem to help. I guess I'll have to contact support.
You don't say specifically which workarounds you tried, but this workaround described in the bug report in the official Adobe feedback forum has worked for most people: Lightroom: Filmstrip is covering / overlapping filter- and breadcrumb bar | Photoshop Family Custome...
I have tried all of the suggestions in that link. I've deleted the com.adobe.lightroom6.plist file from preferences, restarted the computer and LR. I've tried resetting preferences on startup of LR. I've tried unchecking show tab bar in the window menu. I've tried checking and unchecking the film strip in the panel menu. I've tried making sure LR was in standard screen mode. None of these things has worked.
Just to triple check: Did you unselect Window > Show Tab Bar and then restart?
Yes I did. Did not correct the problem.
Perhaps you could post a full-resolution screenshot of your LR window showing the issue. There might be some subtle differences between what you and others are experiencing, and the screenshot might give some clues.
The Tab Bar is visible in the screenshot. The bug happens when Window > Show Tab Bar is checked -- you have to keep it unchecked after restarting LR, or else the bug will occur again.
When I restart LR, the tab bar is automatically checked again. I'm not checking it myself. I don't see an option to keep it turned off. Do you think I should uninstall and reinstall LR?
Spent over 2 hours in chat with support today. They were unable to fix it, but there is an update coming out in a few days that is supposed to take care of it. We'll see, as my case seems to be worst than most. Thank you for your help.
Meanwhile, please add your me-too vote and details of your issue to the bug report in the official Adobe feedback forum: Lightroom: Filmstrip is covering / overlapping filter- and breadcrumb bar | Photoshop Family Custome... . Even though support says an update is coming out that will fix the problem, Adobe customer support is notoriously unreliable, so personally I wouldn't attach high confidence to that statement. There are a few user-interface bugs that Adobe thought was fixed in the last release but weren't.
I have added to that forum. Thanks for your help.
Thanks for your help!
