This problem started a few days ago I am running windows 10 64 bit, windows updated. I found a fix where I deleted a folder called "sl cache " and moved it to the desktop. this allowed me to open and use the program once, after putting in my serial number and then the qualifying serial number from lightroom 5 that I upgraded from. this program had been stable since dec 2016. after I closed the program and went to use it the next day, I got this same message again.
this is an I7 based workstation with 12 gb of ram and 4 tb+ of storage. its system drive is an ssd. system built in 2013. anyone have a solution?
thank you, Steve McG
Hi Steve,
We have documented other fixes for this issue here Server Busy error when launching or using Lightroom on Windows and let us know if that helps.
Akash
Hi Steve,
Akash
Thank you very much, will go through this today. I kept LR 5.7 on the
computer and its working so I am able to do some work first. glad its still
functioning
s mcg
On Mon, Apr 3, 2017 at 1:37 PM, Akash Sharma <forums_noreply@adobe.com>
