If I use the pen tool to create a shape like a square and then in the options panel I select shape why does the fill occur on the outside rather than on the inside? How do I invert the fill?
You (or someone else with access too your computer) have probably set the Pen Tool accordingly at some prior time.
Change the setting in the Options Bar.
I had it set to subtract front shape and changed it to combine shapes. Thanks, that did the trick.
