Hi to all,
I hope you can help me with this one because i couldn´t find any solution for my problem and I´m kinda annoyed by this.
When I work with Photoshop CC 2017 and i make some changes on the picture it doesn´t appear instantly. It also doesn´t make a diffrence what i do, all changes gives me the same result.
The changes only become visible after i zoom in and zoom out again.
I´ve tried two different graphic-cards and i even tried it with Windows 7 and Windows 10, every combination gives me the same bug.
I also tried to use an older graphic-card driver wich didn´t made a difference aswell.
Specs at the moment are:
Windows 10
I7-4770 3,4ghz
GTX 960
16GB DDR3 RAM
Adobe CC 2017
Hi marcapoGmbH,
Have you tried disabling OpenCL in Photoshop preferences?
Also, refer: Photoshop does not recognize my GeForce GTX 960graphic card
Mohit
What are your settings under GPU
Does PS show the GTX 960 as being used?
performance/advanced mode
is it set to basic/normal/advanced?
These are my settings that I use for the GPU
Thank you for your answer Mohit.
I did disable the OpenCL in the preferences but it did not made any difference the problem is still appearing.
Your Link did also not help me either.
anyone still got a idea how to fix this problem?
